pearlm30 Posted February 2, 2009 Share Posted February 2, 2009 MY 95 2.2 auto with 162,xxx miles. The engine runs well, no check engine light. If I let the engine idle in P or N, the car feels OK, but when I put it in gear(D or R or any other gear selection) with the brakes applied, I can feel the vibe thru the whole car. Any advice? Could be engine/trany mounts? Thanks Link to comment Share on other sites More sharing options...
idosubaru Posted February 2, 2009 Share Posted February 2, 2009 so it vibrates immediately, before you're even moving? when was the last tune up? the EJ's should give a cylinder misfire check engine light, but i've seen stranger things happen. a rough running engine can often feel worse when put in gear. check ATF level. sounds like mounts. they're usually not bad after 10 years and only 160,000 miles, but that's not young either for a piece of rubber. Link to comment Share on other sites More sharing options...
pearlm30 Posted February 3, 2009 Author Share Posted February 3, 2009 yes, it vibrates right the way when in gear, before I was even moving. The spark plugs are about 10,000 miles but I guess I will replace them(NGK) Wires look OK How do I check engine/trany mounts? I tried to move/rock the engine itself but it seems pretty stable in there. Thanks again so it vibrates immediately, before you're even moving? when was the last tune up? the EJ's should give a cylinder misfire check engine light, but i've seen stranger things happen. a rough running engine can often feel worse when put in gear. check ATF level. sounds like mounts. they're usually not bad after 10 years and only 160,000 miles, but that's not young either for a piece of rubber. Link to comment Share on other sites More sharing options...
yohy Posted February 4, 2009 Share Posted February 4, 2009 Have either of the front axles been replaced? Link to comment Share on other sites More sharing options...
idosubaru Posted February 4, 2009 Share Posted February 4, 2009 probably more likely trans mounts than engine...if either? Link to comment Share on other sites More sharing options...
nipper Posted February 5, 2009 Share Posted February 5, 2009 Have either of the front axles been replaced? you beat me to it nipper Link to comment Share on other sites More sharing options...
Suzam Posted February 5, 2009 Share Posted February 5, 2009 My old 95 Legacy used to do it all the time. A couple of years ago there was a couple of threads about that era model shaking the open windows it was so bad. What RPMs at idle do you have for neutral and in drive now? I'm not sure if you're having the same problem but if no mechanical solution presents itself other than a tune up or checking the TPS, knock sensor or coolant temp sensor you may have to just live with it. Link to comment Share on other sites More sharing options...
yohy Posted February 5, 2009 Share Posted February 5, 2009 pearlm30, my strongest suggestion would be to read through the following thread,with a focus on post #2 by SmashPDX: http://www.ultimatesubaru.org/forum/showthread.php?t=2489&highlight=vibration This is by far the most informative post on the dreaded auto trans vibration in gear that I have read. Yes, I had the same problem when I replaced both axles on my '97 L auto. Link to comment Share on other sites More sharing options...
pearlm30 Posted February 17, 2009 Author Share Posted February 17, 2009 Thanks everyone for the suggestions, I do remember it started to vibrate after I replaced the front axles. I might get the axles from MWE( if I can afford ) or from a late model phase ! forester@ the junk yard. Thanks again Link to comment Share on other sites More sharing options...
Gloyale Posted February 17, 2009 Share Posted February 17, 2009 Thanks everyone for the suggestions, I do remember it started to vibrate after I replaced the front axles. I might get the axles from MWE( if I can afford ) or from a late model phase ! forester@ the junk yard.Thanks again Let your axles wear in for a while and it should subside. Link to comment Share on other sites More sharing options...
