1980Subie Posted February 2, 2009 Share Posted February 2, 2009 Does anyone know where the primary fuel filter is on the '80 GL? All the auto parts stores show a primary and a secondary, the primary is an in-line filter and the secondary is right next to the fuel pump which is on the drivers side firewall. I have searched for a week trying to find this primary filter that they are talking about to no avail. And to make matters worse no one even has the secondary fuel save for the subie dealership we have here, but i wonder how much they may want for one. Link to comment Share on other sites More sharing options...
the sucker king Posted February 2, 2009 Share Posted February 2, 2009 There is just the one by the pump. I'll confirm that in the factory service manual, but I've had 3 1980 subies and I only know of the one. Link to comment Share on other sites More sharing options...
subiemech85 Posted February 2, 2009 Share Posted February 2, 2009 fuzzy memory did you look in the typical subaru fuel pump hiding spot, infront of right rear tire?? for the underhood pump, is there 3 hoses, 1 on top and 2 bottom side in v shape? wix http://www.wixfilters.com/filterlookup/PartDetail.asp?Part=33201 or only 2 hoses http://www.wixfilters.com/filterlookup/PartDetail.asp?Part=33089 and if it is truly inline http://www.wixfilters.com/filterlookup/PartDetail.asp?Part=33002 Link to comment Share on other sites More sharing options...
1980Subie Posted February 2, 2009 Author Share Posted February 2, 2009 There is just the two hoses. From the gas tank the lines go to the frame by the tire on the right side then go across the body to the left side and actually go into the body and if i followed them correctly are located under the bottom door trim piece. Then they go to the drivers side firewall where they meet the fuel pump and filter. Link to comment Share on other sites More sharing options...
the sucker king Posted February 2, 2009 Share Posted February 2, 2009 yes, just one filter. What body style is your car, I'll send you a scan of the entire fuel system. Link to comment Share on other sites More sharing options...
edrach Posted February 2, 2009 Share Posted February 2, 2009 If your '80 is like my '84 Brat, the primary fuel filter is right next to the fuel pump under the car on the driver's side just forward of the rear wheel. The secondary is actually a vapor trap and has three outlet/inlets. It is usually in the engine compartment up near the firewall on the driver's side. Link to comment Share on other sites More sharing options...
the sucker king Posted February 2, 2009 Share Posted February 2, 2009 If your '80 is like my '84 Brat, the primary fuel filter is right next to the fuel pump under the car on the driver's side just forward of the rear wheel. The secondary is actually a vapor trap and has three outlet/inlets. It is usually in the engine compartment up near the firewall on the driver's side. The 1980 models don't have that pump under the car. Link to comment Share on other sites More sharing options...
subiemech85 Posted February 2, 2009 Share Posted February 2, 2009 The 1980 models don't have that pump under the car. unless they were updated Link to comment Share on other sites More sharing options...
1980Subie Posted February 2, 2009 Author Share Posted February 2, 2009 my car is the station wagon body type. Link to comment Share on other sites More sharing options...
the sucker king Posted February 5, 2009 Share Posted February 5, 2009 her ya go. This is from September 80 FSM Link to comment Share on other sites More sharing options...
