wentz912 Posted February 2, 2009 Share Posted February 2, 2009 From what I understand, to adjust the rear coil-overs on my 86 GL, I need to compress the spring, and then rotate the body of the coil over until it sits on one of the taller notches correct? Now, I've got a super nifty spanner wrench for turning it to a taller notch, but, I haven't got a spring compressor lying aorund. What tools have you guys made do with and had reasonable success? I was thinking maybe a pair of large c-clamps?:-\ Link to comment Share on other sites More sharing options...
subaruguru Posted February 2, 2009 Share Posted February 2, 2009 i used rachet straps Link to comment Share on other sites More sharing options...
pyro926 Posted February 3, 2009 Share Posted February 3, 2009 I made a set out of some all thread, and a couple of hooks I bent and welded to some short pieces of 1/2" tubing which slid over the all thread. Good luck and be careful! *It might be quicker/easier to borrow a set from schucks* Link to comment Share on other sites More sharing options...
Numbchux Posted February 3, 2009 Share Posted February 3, 2009 just use real compressors.....they're like $20 to buy, and at most auto parts shops, free to rent. Link to comment Share on other sites More sharing options...
wentz912 Posted February 3, 2009 Author Share Posted February 3, 2009 Thanks for the help guys! I guess I'll do some bouncing around town after class tomorrow and see if I can find some tools to beg borrow or buy. And since I'm on the topic of suspension and such. The camber is off enough that my "new" snow tires are starting to wear funny. My front left has a weird positive camber even though it's set at the same height as the pass side. And that tire's outside shoulder is noticeabley rounded (by sight and feel) in comparison to the opposite side of the tire as well as the other three tires on the car...I measured from the ground to the center of the fender across the hub on both sides and they are within 1/4" of each other. What, besides the adjustment nuts on the front struts, will affect front end camber? Link to comment Share on other sites More sharing options...
Numbchux Posted February 3, 2009 Share Posted February 3, 2009 front camber is not adjustable. so, in theory......the only way for camber to be different on one side than the other.....is if something is bent. Link to comment Share on other sites More sharing options...
wentz912 Posted February 3, 2009 Author Share Posted February 3, 2009 S**t. I was afraid you would say someting like that. How can I check? Link to comment Share on other sites More sharing options...
