Broken headlight adjuster sockets?
Thread edit: ordered the parts. Send me a message if you want one (or 3).
I'm using 5-6 and keeping 3 spares, so I'll have at least 6 left over (need 3 per side, 6 for both headlights).
This post was about the little nylon ball sockets that go in Subaru headlight adjusters (at least for mid-90s Legacies; assume that other vintages are the same). I found the part under a Toyota listing (11x12.5 mm ball socket). They often break, and it's impossible to properly adjust the headlights if they're not working- especially the sockets for the fixed pivots.
Edited by wondercow2
  • Like 1
  • 7 years later...
Looking for exactly the part you described. Do you have a part number or suppler you ordered from?
Google turned this up: http://teloshop.com/p/119990/m11x125-hole-headlamp-adjuster-nut-15-count.html
I will look around, I think I still have some that I am never going to use - happy to mail them to you. Send me your address via private message.
