sub_dont_touch Posted February 5, 2009 Share Posted February 5, 2009 why is oil leaking from here? Is it a cracked head or rocker cover gasket? What is involved with fixing it? Its an EJ18 impreza. picture: http://img113.imageshack.us/img113/3900/dscn2576wn9.jpg making funny smells (burning oil i suspect??) Link to comment Share on other sites More sharing options...
idosubaru Posted February 5, 2009 Share Posted February 5, 2009 which side is that? looks like the drivers side - hose and oil dipstick tube? good news is this is not a head gasket problem or the signs of anything significant. it's most likely the cam cap oring or seal. the orings are extremely brittle and leak like a seive at this point. these are best replaced with a timing belt job, so just wait until your next one or if it starts leaking really bad. the cam seal and cam cap oring both require the timing belt to be removed to get to them. it's really best to do everything at once - timing belt, cam seals, cam oring, oil pump reseal and at your age a water pump replacement. also a good idea to replace all the timing belt pulleys, ebay timing kits are only $80 or so. great deal. Link to comment Share on other sites More sharing options...
sub_dont_touch Posted February 5, 2009 Author Share Posted February 5, 2009 This is on the passengers side with the dipstick.(right hand side looking from engine bay back) I am from New Zealand. Its leaking around the exhaust. Someone from another forum told me rocker cover gasket.?? I will try get better photos Link to comment Share on other sites More sharing options...
idosubaru Posted February 5, 2009 Share Posted February 5, 2009 yes it could be the rocker cover gaskets. it could also be the cam seal/oring i mentioned above. both will look very similar. Link to comment Share on other sites More sharing options...
sub_dont_touch Posted February 6, 2009 Author Share Posted February 6, 2009 (edited) here are some better photos: http://img7.imageshack.us/img7/3082/copyofdscn2602yi3.jpg http://img7.imageshack.us/img7/241/copyofdscn2594am4.jpg http://img14.imageshack.us/img14/530/copyofdscn2597yx7.jpg im not sure but, it looks like it isn't coming from the rocker cover gasket to me? I don't really know what im talking about but the photos should help. ...i think it is the head gasket? am I right? Edited February 6, 2009 by sub_dont_touch Link to comment Share on other sites More sharing options...
johnceggleston Posted February 7, 2009 Share Posted February 7, 2009 how many miles? ej18 and ej22 are very very similar, i would not suspect the head gasket. yours is a right hand drive, so the oil fill spout is on the passenger side. or more correctly for us in the usa, the passenger side is on the left side of the car. i'd check the bolts and gasket for it. rocker covers look good. could also be cam seal. pull the timing cover on that side and look for oil at the cam shaft / sprocket. head gasket problems are rare. Link to comment Share on other sites More sharing options...
sub_dont_touch Posted February 7, 2009 Author Share Posted February 7, 2009 my car has done 189,000 KMS. it is manual. EJ18. Link to comment Share on other sites More sharing options...
johnceggleston Posted February 7, 2009 Share Posted February 7, 2009 sub_dont_touch said: my car has done 189,000 KMS. it is manual. EJ18. that's about 115k miles. unless you ran it while it was overheating, it should not be the headgaskets. my guess, cam seals. when did you do the timing belt last. is it due? Link to comment Share on other sites More sharing options...
crash321 Posted February 7, 2009 Share Posted February 7, 2009 Head Gasget is fine, that leak is coming from behind the timing cover, Most likely a cam seal. You need to address this as soon as you can because oil on the timing belt will cause the belt to weaken and break. Do what Grossgary said and have all those bits replaced and you will be good for another 100,000 miles:) Link to comment Share on other sites More sharing options...
idosubaru Posted February 7, 2009 Share Posted February 7, 2009 make sure you replace the seal and the oring. the orings are extremely brittle and hard plastic by now. if the timing covers are in good shape not much oil should get on the belt. but if it does, definitely replace the belt while yo'ure in there. i had oil get on a belt two summers ago of a friends car. the new belt lasted a couple months. Link to comment Share on other sites More sharing options...
sub_dont_touch Posted February 7, 2009 Author Share Posted February 7, 2009 (edited) thanks a lot for all the help everyone Timing belt supposedly done at 160,000KMS. Im guessing my engine is non-interface?? So itl be alright if it snaps? I will update when i fix the problem Edited February 7, 2009 by sub_dont_touch Link to comment Share on other sites More sharing options...
ShawnW Posted February 8, 2009 Share Posted February 8, 2009 Its a lot of oil so I would say its the cam seals or that somebody poured oil onto the engine instead of into it. Link to comment Share on other sites More sharing options...
