ericem Posted February 6, 2009 Share Posted February 6, 2009 (edited) Hey guys. I thought my knock sensor was the reason for the code, but I removed it and inspected it, and saw no cracks, and the connector looks to be the newer updated one, looks clean like a new sensor. There was a MAF sensor code too. Need to check again though. What could be the issue most likely if the check engine light goes out at a steady pace, and when the engine is cool? I have a spare MAF sensor, it is the one N/A's use. Think I should pop it in? Anything else that can cause a code like this? Thanks guys! Forgot to add when the check engine light is on, the rpms like to surge, like if i hold my pedal at once place, it will fain rpm's but like surge, and my idle surges up and down. Would a knock sensor do this?? Car is a 94 SS Edited February 6, 2009 by ericem Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 6, 2009 Share Posted February 6, 2009 N/A MAF will not work. Wrong output voltages. The knock sensor is probably bad regardless of what it looks like. Mine didn't look bad either.... drop the $50 on a new one. Clean the MAF with some electrical contact cleaner. The wires get dirty. GD Link to comment Share on other sites More sharing options...
msmithmmx Posted February 6, 2009 Share Posted February 6, 2009 If it's telling you knock sensor then I would replace with a known good one. Post on Things needed. You can grab one for under 10 bucks. Link to comment Share on other sites More sharing options...
ericem Posted February 7, 2009 Author Share Posted February 7, 2009 The one in my N/A wagon is good recently replaced. Going to swap it and see how it runs. I remember the knock sensor was cracked on my N/A and figured I should replace it but there was no code. Made pretty well no difference to be honest. Was looking at fuel economy savings more then anything. I am just hoping it is not a wiring issue, but it doesn't seem to be since if I wiggle the wire etc it doesn't go away only like i said if the engine is somewhat colder then completly warmed up or I am on the highway it is fine. Link to comment Share on other sites More sharing options...
