Check engine light goes out at steady speed
Hey guys. I thought my knock sensor was the reason for the code, but I removed it and inspected it, and saw no cracks, and the connector looks to be the newer updated one, looks clean like a new sensor. There was a MAF sensor code too. Need to check again though. What could be the issue most likely if the check engine light goes out at a steady pace, and when the engine is cool? I have a spare MAF sensor, it is the one N/A's use. Think I should pop it in? Anything else that can cause a code like this? Thanks guys!
Forgot to add when the check engine light is on, the rpms like to surge, like if i hold my pedal at once place, it will fain rpm's but like surge, and my idle surges up and down. Would a knock sensor do this??
Car is a 94 SS
Edited by ericem
The one in my N/A wagon is good recently replaced. Going to swap it and see how it runs. I remember the knock sensor was cracked on my N/A and figured I should replace it but there was no code. Made pretty well no difference to be honest. Was looking at fuel economy savings more then anything. I am just hoping it is not a wiring issue, but it doesn't seem to be since if I wiggle the wire etc it doesn't go away only like i said if the engine is somewhat colder then completly warmed up or I am on the highway it is fine.
