CEL Coolant Temperature Circuit - '95 Lego
  carfreak85 said:
So my girlfriend's car has been throwing the same code for a couple weeks now. Scanned and cleared the codes and the only one there was the coolant temp circuit.
Should I just replace the CTS or could this be a more sinister problem?
I would replace the sensor. It's not expensive and is a common thing to fail. I've had to do it on my 88RX, my 92Legacy, my 95 Legacy, and my 96Legacy. On the 88 and the 96 I was "lucky" enough to experience hot starting issues. When the sensor goes bad it can tell the ECU that the engine is cold when it is really warm. So if you drive the car for awhile and get it up to temp. Then shut it off for only a few minutes and try to start it again, with a bad sensor there is a chance it tells the ECU the engine is cold, which floods out the engine and makes it VERY hard to start.
Keith
Test the CTS with an ohm meter and measure the resistance in relation to the engines temp. Stone cold would be easiest so you know what temp it would be, and full operating temp around 190 degrees, with what value you are measuring against. I believe a haynes manual has the values for this test and you don't need to remove to sensor to do the the test. If the values are out of wack, replace the sensor.
Whenever a code states there is a 'circuit' problem with a sensor, the wiring to that sensor needs to be checked first. There may be an open connection in one of the wires to the sensor, a short to ground or across the leads, possibly a highly resistive connection to the sensor, or some other wiring problem. The sensor itself is most likely ok and replacing it before the wiring is checked may be a needless expense. I my opinion the extra money would be better spent to help purchase a factory service manual.
Edited by Cougar
