Jake DMC Posted February 8, 2009 Share Posted February 8, 2009 Hey all, what tires would fit on a loyale with a 2" lift I don't have the wheels yet but I am looking at a set of 15" Pugs I have read conflicting things on what fits I would like to do little or no trimming or bashing. Thinking of a set of Uniroyal Liberators from wallyworld seems to be the best bang for the buck. This is a low $ daily driver. Thanks for your input. -Jake Link to comment Share on other sites More sharing options...
bratman18 Posted February 8, 2009 Share Posted February 8, 2009 without any trimming, you would be able ti fit some where around a 26" tire. But definitely could fit bigger with a BFH Link to comment Share on other sites More sharing options...
The Scooby Posted February 8, 2009 Share Posted February 8, 2009 look in the off-road section, there is a sticky there. Link to comment Share on other sites More sharing options...
Jake DMC Posted February 8, 2009 Author Share Posted February 8, 2009 Alot of good info in the sticky... But did not really answer my question. All the talk of tire sizes but no one says how much lift or trimming they have. I did find something here [url="http://offroadingsubarus.com/faq.html"they say 25"-26" tire with no lift or trimming 28" with 2" lift and small amount of trimming I guess I was looking for some personnal experiences on what actually works I would hate to go out and buy/mount tires only to find that more work would need to be done to make them fit I am not opposed to a little trim here and there to get what I want but I would like to know what I am getting into before I make my choice. Obviously I am not looking an putting 30" tires on a Loyale with a 2" lift although it looks really cool I am looking for biggest I can get away with, with the smallest amount of trimming and bashing and rubbing. So that being said... What do you think. I am skeptical about the 26" with no lift or trimming. Thanks. -Jake Link to comment Share on other sites More sharing options...
bratman18 Posted February 8, 2009 Share Posted February 8, 2009 I started with a 2" lift in the front of my Brat and the torsion bar cranked up in the rear and I could fit 26" tires. Does that help? Link to comment Share on other sites More sharing options...
The Scooby Posted February 8, 2009 Share Posted February 8, 2009 i have a 2inch suspension lift on my 86 wagon, also running a 215/75/15 wheel/tire combo, i had to trim and bash in the fenders. tires come out to a 28inch tall basically. so with a stock wheel well you should be able to run a 26", or a 27 with minumal cutting/bashing. Link to comment Share on other sites More sharing options...
Gloyale Posted February 8, 2009 Share Posted February 8, 2009 i have a 2inch suspension lift on my 86 wagon, also running a 215/75/15 wheel/tire combo, i had to trim and bash in the fenders. tires come out to a 28inch tall basically. so with a stock wheel well you should be able to run a 26", or a 27 with minumal cutting/bashing. Yeah, I'm thinking a 205/70/15 is about the biggest without trimming. And still I bet that would rub on the rear part of the front wheel wells, and the front of the rear wheel wells. Almost no getting round a little trim. An pnuematic cut-off wheel is a great tool for that. Sawzall can work but it can beat the ************ outta the fender too. Problem is, that with or without lift, the radius of the wheel well is too small to go bigger without trimming. Link to comment Share on other sites More sharing options...
bratman18 Posted February 8, 2009 Share Posted February 8, 2009 Yeah mine were actually 205 75 14 but measured 26 1/4 when new Link to comment Share on other sites More sharing options...
Gloyale Posted February 8, 2009 Share Posted February 8, 2009 If you can find a set of 14inch wheels (2wd 80's nissan and mazda, trucks, Chevy luv wheels, early isuzu trooper) I would recommend that. Cheaper tires. And actually you can ussually find full sets of snowtires used one season on Legacies for $100 bucks. 195/70/14 is stock legacy size and would fit great with no trimming. Link to comment Share on other sites More sharing options...
Jake DMC Posted February 9, 2009 Author Share Posted February 9, 2009 Thanks Guys... Exactly what I was looking for. Personal experiences. So based on this sounds like I want to be somewhere around 27" depending on how much bashing I want to do cutting will have to be done regardless more or less. Thanks again. -Jake Link to comment Share on other sites More sharing options...
Jake DMC Posted February 9, 2009 Author Share Posted February 9, 2009 Oh ya! I almost forgot, discounttiredirect.com has a cool tire size calculator so for instance a 215/75R15 is 27.7" Anyway I thought it was pretty cool. Cheers -J Link to comment Share on other sites More sharing options...
zyewdall Posted February 9, 2009 Share Posted February 9, 2009 And actually you can ussually find full sets of snowtires used one season on Legacies for $100 bucks. 195/70/14 is stock legacy size and would fit great with no trimming. I put this size tire on my '89GL with no lift, and it was okay... little bit of rubbing on the front of the rear wheel wells, and on the front of the front wheel wells on turns -- just barely. Link to comment Share on other sites More sharing options...
