tomeverett13 Posted February 10, 2009 Share Posted February 10, 2009 i have a 83 subaru gl 4x4 that i have to move soon i erfer to go new but can't afford it and the pull a part by where i live has 15 subaru there anyone know the interchange on the cv axles .. what years and style was used i bew out my driverside front axle Link to comment Share on other sites More sharing options...
86HatchShelby Posted February 10, 2009 Share Posted February 10, 2009 EA-82 axles are longer than EA-81 axles, so you have to get them off an EA-81 car. -Jaren Link to comment Share on other sites More sharing options...
edrach Posted February 10, 2009 Share Posted February 10, 2009 86HatchShelby said: EA-82 axles are longer than EA-81 axles, so you have to get them off an EA-81 car. -Jaren Also, turbo axles are different from non-turbo. You would likely be safe with any '82, '83 and '84 wagon; if there are any Brats or Hatches in the mix, you can go as late as 1987 for your axles. Check the write up in the USRM for hints and tips for changing the axle. Link to comment Share on other sites More sharing options...
tomeverett13 Posted February 10, 2009 Author Share Posted February 10, 2009 not sure what the diffrence between a EA-82 and an EA_81 or what i have the hollander interchange but it not giving me that info so if ytou can explain to me the diffrence betwwen is be great Link to comment Share on other sites More sharing options...
bratman18 Posted February 10, 2009 Share Posted February 10, 2009 You have an 83 GL which is the EA81 body style. The next newer body style which was made from 85-94 is known as EA82. The axles do not interchange. an axle from either side of another EA81 will work. Any from 82-89 with the same style body as yours. Link to comment Share on other sites More sharing options...
tomeverett13 Posted February 10, 2009 Author Share Posted February 10, 2009 that what i needed to know Link to comment Share on other sites More sharing options...
bratman18 Posted February 10, 2009 Share Posted February 10, 2009 They did start making that style in 1980 but most likely anything that old will be the older Gen 1 body style which is different. Good luck with your search! Link to comment Share on other sites More sharing options...
tomeverett13 Posted February 10, 2009 Author Share Posted February 10, 2009 bratman18 said: . Any from 82-89 with the same style body as yours. ok now im confused again Link to comment Share on other sites More sharing options...
bratman18 Posted February 10, 2009 Share Posted February 10, 2009 tomeverett13 said: ok now im confused again They made your style car in those years plus a few. Any axles from either side from a car that has the same body style as your car will fit in. Link to comment Share on other sites More sharing options...
tomeverett13 Posted February 10, 2009 Author Share Posted February 10, 2009 sweet Link to comment Share on other sites More sharing options...
bratman18 Posted February 10, 2009 Share Posted February 10, 2009 Here is an EA82 (Thanks The Loyale) And here is an EA81 (Mine) So anything from the EA81 style will fit your car Link to comment Share on other sites More sharing options...
subiemech85 Posted February 10, 2009 Share Posted February 10, 2009 so, let me either make it either clear or confusing!! will axles from a FWD 5spd carter/weber ea81 work for a 4wd AT ea81t ????? if so, if not, Link to comment Share on other sites More sharing options...
tomeverett13 Posted February 11, 2009 Author Share Posted February 11, 2009 here the interchange for my year 1982 - 1987 BRAT 1980 - 1982 GLF 1980 - 1984 DL 1980 - 1984 STANDARD 1980 - 1989 GL 1987 STANDARD 1987 - 1989 GL-10 Link to comment Share on other sites More sharing options...
bratman18 Posted February 11, 2009 Share Posted February 11, 2009 Yup! That's all the years that fit, but just remember that they all have the same body style as your car!!! There are a couple different body styles that intersect with those years, so in order for the axle to fit your car, it has to be the same style. Link to comment Share on other sites More sharing options...
