cv axle interchange
EA-82 axles are longer than EA-81 axles, so you have to get them off an EA-81 car. :)
-Jaren
Also, turbo axles are different from non-turbo. You would likely be safe with any '82, '83 and '84 wagon; if there are any Brats or Hatches in the mix, you can go as late as 1987 for your axles. Check the write up in the USRM for hints and tips for changing the axle.
