kdixey Posted February 11, 2009 Share Posted February 11, 2009 So I decided that I won't be putting out my 86 GL (brownie) to pasture just yet. Partly because I may not be employed come Summer and partly because I LIKE having no car payment. So...brownie needs some help. He leaks oil (and more than is "normal" for a Subaru). Smells of gas when I start up (I understand it needs a reseal on the carb, but I have a Weber in a box so I'll likely just go that route). Basically I'm looking for a good Subaru mechanic in Bellingham, WA (or Seattle if I have no other options) that YOU would trust to rebuild the engine. I was originally going to go with CCR but at nearly $2500 for a rebuilt engine it is not looking like the wise choice. I've been to Precision Tune and Harmony Motorworks so far and both have been disasters. Any recommendations? I'm all ears. As much as I'd love to do it myself (and I have done a number of small things on the car with the help of friends) I just don't have the skill or the space to pull it off. Since I'm not sure about being employed after June I figure I'd better get it done while I'm still getting a paycheck. Any ideas? :-\ Kevin Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted February 11, 2009 Share Posted February 11, 2009 while you are employed, buy the parts and tools to fix it while you are collecting unemployment, rebuild the engine until then, replace the valve cover gaskets and grommets. easy 1/2 hr "in frame" job, especially if you use a gear wrench carb reseal can be done in a LONG day Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted February 11, 2009 Share Posted February 11, 2009 Rods on the Guide Quote Link to comment Share on other sites More sharing options...
kdixey Posted February 11, 2009 Author Share Posted February 11, 2009 while you are employed, buy the parts and tools to fix it while you are collecting unemployment, rebuild the engine until then, replace the valve cover gaskets and grommets. easy 1/2 hr "in frame" job, especially if you use a gear wrench carb reseal can be done in a LONG day I like the inventiveness, only problem is that I live in a small apartment so I don't have anyplace to work on the car. If I can score a yard or garage with the unemployment then I think I'll go that route. I have a Weber sitting around so I'm going to skip the carb reseal and put it on (or have it done). Quote Link to comment Share on other sites More sharing options...
kdixey Posted February 11, 2009 Author Share Posted February 11, 2009 Rods on the Guide Thanks Quote Link to comment Share on other sites More sharing options...
