thecarman Posted February 11, 2009 Share Posted February 11, 2009 The Haynes manual says I need to pull the starter off of my EA82T before pulling the engine. Is that correct? I thought since the starter is bolted to the trans, and not contacting the flywheel when not in the process of starting, I could just leave it on there. Do I really need to pull it? Thanks! Richard Link to comment Share on other sites More sharing options...
chef_tim Posted February 11, 2009 Share Posted February 11, 2009 IIRC one of the bolts goes all the way through and that one needs to come out. The other one, I think is a stud, and the starter can stay conected to the bellhousing on that side. Later, Tim Link to comment Share on other sites More sharing options...
mudduck Posted February 11, 2009 Share Posted February 11, 2009 No need to pull the starter. Link to comment Share on other sites More sharing options...
Tcat55371 Posted February 11, 2009 Share Posted February 11, 2009 It's also alot easier to loosen that one that doesnt have to come out before you put the motor back in. Link to comment Share on other sites More sharing options...
Gloyale Posted February 11, 2009 Share Posted February 11, 2009 Tcat55371 said: It's also alot easier to loosen that one that doesnt have to come out before you put the motor back in. I've NEVER needed to do this. Not htat it wouldn't help, I'm just saying in well over a hundred Subaru Motor pulls I've never needed to remove one. If you are dropping a transmission through thte bottom then it DOES definately have to come out. Pulling engine, it can stay Link to comment Share on other sites More sharing options...
