Do I have to remove starter to pull engine? (EA82T)
The Haynes manual says I need to pull the starter off of my EA82T before pulling the engine. Is that correct?
I thought since the starter is bolted to the trans, and not contacting the flywheel when not in the process of starting, I could just leave it on there.
Do I really need to pull it?
Thanks!
Richard
It's also alot easier to loosen that one that doesnt have to come out before you put the motor back in.
I've NEVER needed to do this. Not htat it wouldn't help, I'm just saying in well over a hundred Subaru Motor pulls I've never needed to remove one.
If you are dropping a transmission through thte bottom then it DOES definately have to come out.
Pulling engine, it can stay
