ahole Posted May 2, 2009 Share Posted May 2, 2009 About the top 1/3 of the engine case is just a cover with the starter and air filter/box inside. The engine itself is actually very compact like a subaru. Link to comment Share on other sites More sharing options...
bigo1966 Posted May 13, 2009 Author Share Posted May 13, 2009 Hey Bill, If you read this could you post a pic of your extended radius rods? Its time to get those 32's on the Sedamn. Link to comment Share on other sites More sharing options...
The Beast I Drive Posted May 14, 2009 Share Posted May 14, 2009 I'll get some pics today and post them up tonight for ya! -Bill Link to comment Share on other sites More sharing options...
bigo1966 Posted July 6, 2009 Author Share Posted July 6, 2009 Wahoo!!!!!! Link to comment Share on other sites More sharing options...
ezapar Posted July 6, 2009 Share Posted July 6, 2009 Ok. . . I'm stoked to see what happens. Link to comment Share on other sites More sharing options...
The Beast I Drive Posted July 6, 2009 Share Posted July 6, 2009 That is going to be pretty sweet, 120hp, it has more power than the stock motor! Should have plenty of torque with the extra trans, enough to turn those 32" tires eh? Here's those pics of the extended radius rods I forgot to post :-\ sorry bout that Those are extended 1 1/2", which was too much, I had to move the motor crossmember forward 1/2" to make them work. I cut the rods, cut a piece of stock 1 1/2" long, slid it into the pipe, then plug welded both sides of the pipe to the radius rods. Should be plenty strong, but I have yet to test it, gotta finish the wiring and get an EJ22 in it. This car aslo has a 4" lift and 31" tires on it -Bill Link to comment Share on other sites More sharing options...
bigo1966 Posted July 6, 2009 Author Share Posted July 6, 2009 How much should I extend mine? 1", .75"? Link to comment Share on other sites More sharing options...
The Beast I Drive Posted July 6, 2009 Share Posted July 6, 2009 It appears 1" is the way to go, its less stress on the CV joints, and you wont have to move the engine crossmember. There will be extra stress on the pivot bushings on the lower arms though unless you modify the control arms or slot the mounting holes on the crossmember. You will still need some gracious bashing/ fender cutting to clear those big meats, and they still might rub a bit... -Bill Link to comment Share on other sites More sharing options...
bigo1966 Posted August 18, 2009 Author Share Posted August 18, 2009 Well the in next month I need to extend radius arms, fix all broken parts from my Bachelor Party, get the 32" tires on the car, I picked up some 220 lb springs for the rear of the car, 40 bucks a pair, brand new, so i need to replace those also. Rear disc swap. Ill get some pics up when the fun starts........And then.....Motor swap!!!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted August 18, 2009 Share Posted August 18, 2009 Well the in next month I need to extend radius arms, fix all broken parts from my Bachelor Party, get the 32" tires on the car, I picked up some 220 lb springs for the rear of the car, 40 bucks a pair, brand new, so i need to replace those also. Rear disc swap. Ill get some pics up when the fun starts........And then.....Motor swap!!!!!!!!!!!!!!!!! got that bike engine in there yet?? lets see it Link to comment Share on other sites More sharing options...
bigo1966 Posted August 18, 2009 Author Share Posted August 18, 2009 Not yet, but soon. Very soon. I cant wait. I want to do it now, a few weeks at the most. Link to comment Share on other sites More sharing options...
bigo1966 Posted August 31, 2009 Author Share Posted August 31, 2009 New to me Shoes. I still need to bash and cut more steel. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 2, 2009 Share Posted September 2, 2009 looks good what size are those shoes? Link to comment Share on other sites More sharing options...
bigo1966 Posted September 3, 2009 Author Share Posted September 3, 2009 They measure right now 31.5x8. The actual size is the metric bs 265/85R16 maybe? . I extended the front radius rods by 1", the way Bill did his and helped a TON. I still need to cut more out of the rear. When the tire get tucked like in the pic above the car does not want to move at all. Link to comment Share on other sites More sharing options...
The Beast I Drive Posted September 3, 2009 Share Posted September 3, 2009 They measure right now 31.5x8. The actual size is the metric bs 265/85R16 maybe? . I extended the front radius rods by 1", the way Bill did his and helped a TON. I still need to cut more out of the rear. When the tire get tucked like in the pic above the car does not want to move at all. If you lift the rear up to 6" you wont have to cut anymore to clear... But I figure you want to keep a good approach angle, so I would massage it with the BFH before you whip out the grinder -Bill Link to comment Share on other sites More sharing options...
bigo1966 Posted September 11, 2009 Author Share Posted September 11, 2009 (edited) Ive finally started the motor swap. Lastnight i took the output driveshaft and the clutch to a friends house with a lathe. Turned down a few parts and welding fixtures. As soon as i get the pics from him i will upload them. I also went to K&K and picked up a 1/4" plate to secure to the front of the subaru tranny to provide a good solid mount for supports. Notice the car sitting a little higher at the moment....Missing something. Edited September 11, 2009 by bigo1966 Link to comment Share on other sites More sharing options...
bigo1966 Posted September 13, 2009 Author Share Posted September 13, 2009 Bad, Bad, Bad, Bad, Bad, Bad, Bad, Bad, Bad, Bad, Bad, Bad, Bad, Bad, news. THE OUTPUT OF THE V65 MOTORCYCLE ENGINE ROTATES THE WRONG WAY!!!!!!!!!!!!!!! I SHOULD HAVE NOTICED THIS MONTHS AGO. AND OF COURSE I ALREADY PULLED THE SUBARU ENGINE, LOOKS LIKE ILL BE PUTTING IT BACK IN THE CAR. SO BUMMED:( SO VERY VERY BUMMED. Link to comment Share on other sites More sharing options...
The Beast I Drive Posted September 13, 2009 Share Posted September 13, 2009 Put the engine and tranny in the trunk, and run the whole drivetrain backward... -Bill Link to comment Share on other sites More sharing options...
Redcap Posted September 13, 2009 Share Posted September 13, 2009 Bad, Bad, Bad, Bad, Bad, Bad, Bad, Bad, Bad, Bad, Bad, Bad, Bad, Bad, news. THE OUTPUT OF THE V65 MOTORCYCLE ENGINE ROTATES THE WRONG WAY!!!!!!!!!!!!!!! I SHOULD HAVE NOTICED THIS MONTHS AGO. AND OF COURSE I ALREADY PULLED THE SUBARU ENGINE, LOOKS LIKE ILL BE PUTTING IT BACK IN THE CAR. SO BUMMED:( SO VERY VERY BUMMED. Use a pair of gears to change the rotation. Link to comment Share on other sites More sharing options...
bigo1966 Posted September 14, 2009 Author Share Posted September 14, 2009 Well looks like im going to go with plan B. Mount stock motor in trunk. Hydraulically couple engine to trans. Im being serious. Who here are my resident Hydraulic experts? Link to comment Share on other sites More sharing options...
The Beast I Drive Posted September 14, 2009 Share Posted September 14, 2009 My dad's been doing hydraulics for the better part of 40 years.... -Bill Link to comment Share on other sites More sharing options...
bigo1966 Posted September 14, 2009 Author Share Posted September 14, 2009 Ask him what he thinks about the idea. I think I would be in way over my head. After some reading might be a little too much work. Link to comment Share on other sites More sharing options...
The Beast I Drive Posted September 14, 2009 Share Posted September 14, 2009 Really it should not be that hard... But there will be few parts you will need to make it work. -Bill Link to comment Share on other sites More sharing options...
bigo1966 Posted September 14, 2009 Author Share Posted September 14, 2009 OK......Ive got it. I cant bail on the motorcycle powered subaru yet. I have to find a right hand side shaft driven motor. That will turn the correct way. Wahoo, im back in the game. Goldwing, CB900, ST1100, etc. Link to comment Share on other sites More sharing options...
The Beast I Drive Posted September 15, 2009 Share Posted September 15, 2009 Right on man, I am really interested in seeing that thing run with the motorcycle engine/trans in it -Bill Link to comment Share on other sites More sharing options...
