My wifes '95 legacy 2.2 starts rough. Harder when
cold, but chuggs almost all the time.
No codes...........
We changed out the Coolant Temp Sensor in hopes
that was it.......... no change.
Once it's warmed up and shut down, it starts fine.
Head scratcher
Yes we replaced the fuel filter a week or two before
we did the Coolant Temp Sensor.
She has to always give it a little gas to get it going,
then it chugs. At 0 or below it can be a hard start.
Only been doing it for a month or two. Getting really
frustrating.
We've run injector cleaner in the gas as well.
New plugs and wires too.
Sorry I don't have a solution but I can tell you what I tried when I had this problem. I had a 94 legacy and it would do almost this same thing. It would crank and crank and crank when the engine was cold and would eventually start. Usually had to jump it to start it as it would wear the battery down. Once it was started though it would run just like nothing was wrong. Even if you turned it off right away it would start right back up. I thought I was losing pressure in the fuel system so I tried turning the key on and off about ten times so that the fuel pump would run. Then I replaced the coolant temp sensor, mass airflow sensor, throttle position sensor, and even the ECM (not at same time). Nothing worked. Luckily most of these parts were free cause my friend had a junker. I lived with this problem for months because the car ran great once it was started. After about $300 and three mechanics didn't figure it out I finally traded it in for a 95 legacy. Since then I have wondered what the heck it was.
Chugging sounds like it went into a limp home mode. Maybe a flight test would be in order by a mechanic, unless you have those tools. Mine did the same things when my car went through a cluster failure, A mouse chewed up alot of wiring to several sensors ($$$$$$$$), but my chugging issue stemmed from an idle air control circuit and had to replace that particular valve. All good now.
New plugs and wires........ but I doubt they are
the reason. The intermittent nature is a baffler.
Ran injector cleaner through more than once. We
have not had the fuel pressure tested. But why
would it run fine at most other times??
Could be a fuel pump starting to go. If it is original at that age then that would be suspect. The only reason a car would not run would be because you don't have air (engine condition), fuel (pump, pressure, filter, injectors), or spark (bad coil, plugs, wires) Subies don't like other brand plugs and wires but the OEM type, a bit more money up front but worth not dealing with performance problems.:)
I normally agree on the spark plug issue. But I am
confident this is not ignition related.
Fuel is something I will check into. But I still get
puzzled why it starts like a champ all other times
after a cold start (by cold I me sub freezing).
  Skip said:
I'll assume you are positive you changed the correct
coolant thermo sensor not the temp sensor for the dash gauge.
Not really.......... I was 350 miles away. The parts store guy
gave it to her, and a mechanic put it in. Like $70 labor....
I'll check. Are they both located in the same area? Is one
easier to install??
easier to install??
maybe call your wife or the parts store guy and get the part number to cross check. location mat not matter if they gave her the other sensor. the shop installed the part supplied.
it appears they are right next to each other, passenger side, under the intake, threaded in to the coolant pipe that goes forward to the top radiator hose. the one you want is closer to the middle, item #1 below, the outside one is for the instrument cluster gage, item #4 below.
the gage sensor has only one wire ( pics from advance auto parts)
gage sensor
coolant temp sensor
part numbers can be found here:
http://opposedforces.com/parts/legacy/us_b11/type_25/cooling_system/water_pipe_1/
Edited by johnceggleston
  Sundance said:
John,
We have confirmed that the correct sensor was installed.
Unfortunately, the problem remains,,,,,
I would have a fuel volume and pressure test done when the car is stone cold. It really sounds like a fuel problem. Good luck:) Let us know what you find.
  • 2 weeks later...
Hi,
I have a 2007 Subaru Impreza. It does the same thing. The dealer says nothing wrong with my car. They changed the spark plugs (they get oily and wet when I crank it too many times) and installed a new program a couple of times. They also got some computer readings to send to Japan.
I have written my problem before in this forum and I was told that the coolant sensor might be bad. However, Subaru mechanic in Turkey said that the engine check light would be on if some sensors were bad.
Since it is under warranty, I have just sued the dealer. They have not been able to fix it. This is very frustrating and I am tired of this problem.
I hope somebody can solve this problem. It is obvious that Japanese engineers cannot solve this problem.
Good luck.
Mehmet
possible injector leakdown, take a battery and check them if you hear a click then they are doing their job, if not then while sitting it may be flooding, another sign of this is your mileage will suck you should be in the 23- 25 range if its lower then this may be your prob, and the injector is stuck open givin one or more cylenders gas all the time, also lowering pressure on the other ones. also check your coil, start it up and one by one pull the plugs off the coil they should arc to the coil when working, but be carefull this is a job for a good rubber glove because if it arcs thru your finger it will feel like flowers blowing in a warm spring breeze.
  Sundance said:
Well add a new fuel pressure regulator to the new parts
pile............
Did nothing................ Still starts like a pig.
Did you check the regulator's operation before replacing it?
If so, what was the fuel pressure?
Have you tried resetting the ECU after parts replacement?
It was installed by a mechanic
I will check, I would hope it was bad........ $180 bad.
I am on the road...........
How do you reset the ECU?
