does the ej18E in my 95 impreza have one or two timing belts...?
one, the ej18 is so much like the ej22 thr timing belts are probably the same. same heads, same pulleys, same, same. the pistons and rods may be different.
every post you read about the ej22 timing belt job is also true for the ej18.
Edited by johnceggleston
