discopotato03 Posted February 15, 2009 Share Posted February 15, 2009 Hi all , I'm fed up with the silly 4 x 140 stud pattern on my L RX Turbo and want to know if anyones drilled say another set of holes for the Datsun 4 x 114.3 pattern . I've looked at a front drive flange and I think its possible to do this so I'm curious to know if anyones done it yet . Cheers Adrian in Australia . Link to comment Share on other sites More sharing options...
bratsrus1 Posted February 15, 2009 Share Posted February 15, 2009 Hi This is Jerry, yes i have redrilled my hubs to 4 on 4 1/2 inch bolt circle to fit toyota. I have been running 4 bolt cragars on my hatch and i have over a hundred thousand miles on them work great. Also the wheels i have on my hatch are rear wheel drive wheels and i have had no problems. I also have rear disc brake on my car, the rear hubs are simple to redrill. Thanks Jerry Link to comment Share on other sites More sharing options...
4x4_Welder Posted February 15, 2009 Share Posted February 15, 2009 I always thought the center alignment hub was too big for the smaller pattern rims. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 15, 2009 Share Posted February 15, 2009 I Did That Redrill in Both my Wagons... Look at my List of Writeups at my "Public Profile" Page, one is about how to Change the Rear Wheels` Lock System, there you can see Pictures of How I Redrilled the Bolt Pattern. I Did it Long Long Time Ago... several thousand Miles and Trips have Done Without issues... I always thought the center alignment hub was too big for the smaller pattern rims. ... Yes, the Rims` Center Holes are Smaller, so You`ll need to Reduce the Center Hubs Diameter at a Machine Shop. Kind Regards! Link to comment Share on other sites More sharing options...
discopotato03 Posted February 16, 2009 Author Share Posted February 16, 2009 I don't suppose you have any pics of the front hub and or rear disc brake ones redrilled ? Cheers A . Yeah , always though Subaru drums were an easily machined up disc rear hub in the making ! With the drum part removed you could possibly machine the hollow stem section to offset in inwards enough to get an external disc over it . Link to comment Share on other sites More sharing options...
