swapping 4wd parts into a 2wd (gen 1)
When I had two '75's side by side I could plainly see that the underbodies are a little different.All due to the 4WD.
I still think it can be done.Infact,if I get this '75 coupe I'm going to make the attempt.Probably use an SPFI EA82 if I can wedge it in there.The R and D will be fun I'm sure.THose coupes have such a flat bottom.Probably just weld a subframe in like the Gen II Brat lift that Bruce from Maine has(zrBrat,used to be on the old board).
Please post,whoever does the deed first.Miles,you done this yet?
