beans Posted February 18, 2009 Share Posted February 18, 2009 alright i swapped an ej 22 into an 1986 subaru gl wagon from a 1993 subaru legacy.. so i had spark problems.. i figured that out to be a stupid wiring problem.. not the car will run but.. it will only run for about 15 seconds or so.. i am thinking it is a fuel pressure problem.. there is a 1987 spfi fuel pump in it.. i can prime the system for 2 cycles of the key and it will start run for a little not long at all.. then just die.. anything you can think of will help like maybe which fuel pump to use and where to put it in the system.. right now it is mounted on the strut tower right off the ea fuel lines.. ???????:-\:-\:-\:-\:-\ Link to comment Share on other sites More sharing options...
s'ko Posted February 18, 2009 Share Posted February 18, 2009 What CEL codes are you getting? you problem might not be the fuel pump, the SPFI pump should be adequate to handle the fuel needs. Link to comment Share on other sites More sharing options...
The Scooby Posted February 18, 2009 Share Posted February 18, 2009 lol, check out my build on my EJ swap into my 86 wagon, im having the same problem. i found that the ECU is not giving 12V to the fuel pump relay so i have to take the harness back out of the car and OHM out every wire now. Link to comment Share on other sites More sharing options...
capn_r Posted February 18, 2009 Share Posted February 18, 2009 Isn't the SPFI fuel pump quite a bit lower pressure than the EJ's port injected system? Link to comment Share on other sites More sharing options...
beans Posted February 18, 2009 Author Share Posted February 18, 2009 The Scooby said: lol, check out my build on my EJ swap into my 86 wagon, im having the same problem. i found that the ECU is not giving 12V to the fuel pump relay so i have to take the harness back out of the car and OHM out every wire now. i checked for 12 volts to the fuel pump when it is running.. i have 11.7 volts. it stays at 11.7 volts until the car dies then it goes to zero.. Link to comment Share on other sites More sharing options...
The Scooby Posted February 18, 2009 Share Posted February 18, 2009 yep, have you checked to make sure you are getting a 12V signal and ground at your fuel pump relay? Link to comment Share on other sites More sharing options...
beans Posted February 19, 2009 Author Share Posted February 19, 2009 i figured it out.. i never cut the old fuel pump out of the system.. so it was restricting flow.. i put a new line in completely cutting out the pump and now it runs and runs and i love ej swaps.. the car has power its great thanks much Link to comment Share on other sites More sharing options...
what huh Posted February 20, 2009 Share Posted February 20, 2009 what do you mean cut out the old fuel pump? were you running two fuel pumps? Link to comment Share on other sites More sharing options...
Phizinza Posted February 20, 2009 Share Posted February 20, 2009 capn_r said: Isn't the SPFI fuel pump quite a bit lower pressure than the EJ's port injected system? No, pumps are the same pressure. Its the engine that runs different pressure. The SPFI lowers it to about 22psi. While the EJ uses about 45psi. The pumps are good for upto 60psi I've heard. Link to comment Share on other sites More sharing options...
Phizinza Posted February 20, 2009 Share Posted February 20, 2009 beans said: i figured it out.. i never cut the old fuel pump out of the system.. so it was restricting flow.. i put a new line in completely cutting out the pump and now it runs and runs and i love ej swaps.. the car has power its great thanks much Yeah, only way you can keep the old pump is if you run a surge tank. Old low pressure pump pumps into the surge tank, high pressure pump pumps out of the surge tank into the engine and back into the surge tank. Only need/want to do this with older EA81 non-turbo cars though. Link to comment Share on other sites More sharing options...
oldschool Posted February 21, 2009 Share Posted February 21, 2009 Hey, contact Numbchux he is a wiz on the ej swap. And you don't need a surge tank. You can also run two draw fans on the inside of your radiator. Link to comment Share on other sites More sharing options...
Numbchux Posted February 22, 2009 Share Posted February 22, 2009 Phizinza said: No, pumps are the same pressure. Its the engine that runs different pressure. The SPFI lowers it to about 22psi. While the EJ uses about 45psi. The pumps are good for upto 60psi I've heard. no, no, no. Carbed uses about 10 psi. FI EA82s and N/A EJs use about 40 psi, and turbo EJs use the same pressure, but about double the cfm. an SPFI EA82 fuel pump will run an N/A EJ22 without any difficulty. Link to comment Share on other sites More sharing options...
The Scooby Posted February 22, 2009 Share Posted February 22, 2009 yep, its running my 86 lifted wagon without any hickups. does 75mph down the highway in 5th gear. ive NEVER been able to use 5th gear in this car. Link to comment Share on other sites More sharing options...
Phizinza Posted February 23, 2009 Share Posted February 23, 2009 Numbchux said: no, no, no. Carbed uses about 10 psi. FI EA82s and N/A EJs use about 40 psi, and turbo EJs use the same pressure, but about double the cfm. an SPFI EA82 fuel pump will run an N/A EJ22 without any difficulty. :-\ just what I read on this forum. I know they use 40psi pumps, but a pump will only generate that pressure if flow is restricted enough on the return line. I also know EJ22 OBD1 fuel pressure is regulated by vacuum, or at least mine was. Link to comment Share on other sites More sharing options...
wongie Posted March 12, 2009 Share Posted March 12, 2009 beans said: alright i swapped an ej 22 into an 1986 subaru gl wagon from a 1993 subaru legacy.. so i had spark problems.. i figured that out to be a stupid wiring problem.. not the car will run but.. it will only run for about 15 seconds or so.. i am thinking it is a fuel pressure problem.. there is a 1987 spfi fuel pump in it.. i can prime the system for 2 cycles of the key and it will start run for a little not long at all.. then just die.. anything you can think of will help like maybe which fuel pump to use and where to put it in the system.. right now it is mounted on the strut tower right off the ea fuel lines.. ???????:-\:-\:-\:-\:-\ wanted some info on you engine swap... what type of trans do you have in your wagon and was it easy to do the engine swap, any wiring issues and problems? I have a 92 loyale wagon 3EAT with 1.8 EA82 and heard i can do a EJ22 & 4EAT swap. Link to comment Share on other sites More sharing options...
