gm top engine / injector cleaner
  • 2 weeks later...
Don't ever use the GM Injector cleaner in the tank- will destroy pump seals. I used to work as a GM tech. GM dealers use a setup to put the cleaner in the fuel rail near the injectors to clean the injectors (bad design - would clog up with some brands of gas- mostly the regional chains). Top engine cleaner can't go in either - the injector cleaner and top engine are two different products. If you have the top engine it can be use to clean the carbon out of the valves and in the heads-run the engine until warm, just disconnect a vacuum hose to the intake and put it in the can (if it is not spray can) with the engine running. Be prepared to rev the engine to keep it running. let the last 1/4 can stall the engine. Then let is sit overnight- will be little hard to start in the morning but it will remove any carbon in there and your whole neighborhood will think you are having the largest BBQ ever (no joking- smells like 100 BBQ grills lit all at once- if you neighbors are picky- don't do this in the summer or park a few blocks away)
heheh did this with a spray bottle of water, the amount of smoke it made was ENORMUS.
And part of me thought it was really really cool
nipper
I used gm top engine treatment on a carburated 79 monte carlo V8 305 once. With air cleaner cover off, dumped bottle into carb with engine running 3/4 throttle choke open til the engine Dies. Let sit over night.
Next morning went to start. Here is the biggy.....it will not start worth a ************. Crank crank crank cough sputter knock cough sputter. That is the okd carbon busting loose. Finally it may start fogging the Whole town* neighbors will think you blew it up. You will think you blew it up. That engine ran forever though after that. Was good on the V8
Subaru service manuel says to use the Gm top engine cleaner to clean the idle air control solenoid valve.It says to pour it into the large air hose from the air filter housing going to the idle air valve whille holding throttle at 2000 rpms and wait for the white smoke to clear. What scared me off using anything through that tube was the next step which is to reset the TPS with Subaru scan tools. (beyond my talent/apprehension level) Bob
Sorry, I didn't mention the service manuel I was referring to was for a 2.5 DOHC for 1999 Outbacks, I don't know if the 2.2 has similar layout or not but on the 2.5 it's a large line, probably an inch diameter going into the idle air control valve off of the air intake assembly. Bob
