no compression on one side????
one of my friends has a 2000 outback i dont know as much about the newer subarus as i do the older, but he was telling me that his engine just went out i asked questions. he said the car just stoped the engine wouldnt run. so he went to do an compression test and said that one side of the engine was getting compression and the other side wasnt niether cylinder. what would cause no compression on one side??
Thanks
SS
Don't know I never worked on the old ones and I send heads out to be fixed.
You gotta look for the original cause though. TB skip a few teeth? Cam pulley? Something caused the wreck.
Something had to happen to wipe out valves in more than one cylinder - it's not like you just dropped one valve.
Dave
ej22 in place of a 2000 2.5 SOHC - I don't know about that swap. Think it would be ugly.
I do have an engine here not torn down (bad bearings) that has heads, etc. Intake is already off.
Let me know if you think you need parts and I can look at tearing it down.
Most likely a broken timing belt caused the trouble. It looks like this is an interference engine so bent valves and perhaps other damage occured. If your friend wants to fix this it may be best to replace the entire head with a new one. Check the compression on the other side to see if something is needed to be done on that side also.
Edited by Cougar
