hebrewhammer Posted February 23, 2009 Share Posted February 23, 2009 right...? the only difference is a different stroke, ie diff crank but everything else is the same right...? Link to comment Share on other sites More sharing options...
The Beast I Drive Posted February 23, 2009 Share Posted February 23, 2009 the pistons are different too I believe, Im sure there are more differences than you think... the block might be the same or close, but I have no real clue there... -Bill Link to comment Share on other sites More sharing options...
bheinen74 Posted February 23, 2009 Share Posted February 23, 2009 ej18 has block stamp ej18 ej22 has block stamp ej22 that part different obviously. Link to comment Share on other sites More sharing options...
johnceggleston Posted February 23, 2009 Share Posted February 23, 2009 the crank and connecting rod bearins are the sam, this means the crank is the same? the piston rings are different. i don't have a guess about the stroke, buyt i bet the bore is different. that would be the easiest way to increase the displacement. Link to comment Share on other sites More sharing options...
ferret Posted February 24, 2009 Share Posted February 24, 2009 From MY99 Shop manual ( USDM non-turbo): EJ18 Bore 92mm Stroke 67mm EJ22 Bore 96.9 Stroke 79mm EJ25 Bore 99.6 Stroke 79mm Link to comment Share on other sites More sharing options...
Ioku Posted March 4, 2012 Share Posted March 4, 2012 From MY99 Shop manual ( USDM non-turbo): EJ18 Bore 92mm Stroke 67mm EJ22 Bore 96.9 Stroke 79mm EJ25 Bore 99.6 Stroke 79mm I know this is an older post but wanted to clear up some misinformation in case others find it. EJ18 Bore 92mm Stroke 67mm, this is wrong, the bore is 87.9 mm and the stroke is 75mm EJ22 Bore 96.9 Stroke 79mm, the bore is right but the stroke is 75mm EJ25 Bore 99.6 Stroke 79mm, this one is correct. Link to comment Share on other sites More sharing options...
ccrinc Posted March 4, 2012 Share Posted March 4, 2012 Yeah, the EJ18 is a smaller bore. Everything else except pistons and therefore smaller rings, is the same between the EJ18 and the EJ22. They were designed to be swapped between the two. Everything from an EJ18 (intake, exhaust, accessories, etc.) fit an EJ22 and vice versa. HP difference: EJ218 = 115hp. EJ22 = 130-135hp. Link to comment Share on other sites More sharing options...
Gloyale Posted March 4, 2012 Share Posted March 4, 2012 EJ22 Bore 96.9 Stroke 79mm, the bore is right but the stroke is 75mm That info came from a 99' shop manual. Meaning it's referencing the Phase II, EJ22. The Phase II 2.2 is an oddball. Basically a smaller bore Phase II 2.5. So for 99 only EJ22 the bore/stroke may be correct. (96.9/79mm) Link to comment Share on other sites More sharing options...
tallwelder81 Posted August 14, 2012 Share Posted August 14, 2012 i know, i know..... this thread is older than moses' grandpa. but im curious, can my ej18 be STROKED? doesnt stroke tend to create low-mid rpm torque? where bore tends to create mid-high rpm horsepower??? do the ej22 con-rods swap into my ej18? and everything else <fuel lines, ecu, harness, pistons, rings, etc> could stay the same stock original ej18 parts?? Link to comment Share on other sites More sharing options...
WoodsWagon Posted August 15, 2012 Share Posted August 15, 2012 You will probably need custom pistons because the distance between the center of the wristpin and the deck of the block gets shorter the more you stroke the engine out. Cheaper to just run a 2.2l or a 2.5l. Link to comment Share on other sites More sharing options...
