Scott in Bellingham Posted February 25, 2009 Share Posted February 25, 2009 can I put a 95 Automatic from a Impreza into a 96 Legacy wagon that has a 5 speed ? Link to comment Share on other sites More sharing options...
lmdew Posted February 25, 2009 Share Posted February 25, 2009 You can do anything, the question is it worth the trouble. Most swaps here are going the other way, Auto to a Manual. You'd need at least the following Starter Transmission Flex Plate and bolts Trans Cross Member Trans Drive Shaft Rear Diff is the gear ratios are different Break Box Trans ECU Associated Wiring This is a large project, it would be best accomplished with a complete doner car to get all the parts Link to comment Share on other sites More sharing options...
screwbaru2 Posted February 25, 2009 Share Posted February 25, 2009 If you mean a motor from an auto into a car with a manual than yes. Check for egr compatiblity. I think the 95 auto's had egr and 96 manual's did also. Although that's not hard and fast. I have a 95 manual without a egr and 2 96autos with egrs. Also have a 97 manual with egr. So check the egr. Link to comment Share on other sites More sharing options...
EVOthis Posted February 25, 2009 Share Posted February 25, 2009 +1^... I never understood Subarus intentions when it came to the Gen. 2 EGR systems( as to which vehicles had them and which didnt)....I have a 96' Legacy manual w/o EGR... Link to comment Share on other sites More sharing options...
