My 2000 4-cyl A/T OBW has 120K; all original suspension components; never wrecked; new tires. If I'm going about 50 mph and back off the throttle, the car 'trembles' briefly as it decelerates. Also trembles/shakes at low speeds with uneven curb cuts, speed bumps, etc. What is the likely explanation? What bushings/mounts/etc. typically wear out by this mileage and might explain this problem? TIA.
There are these things called tune-ups.
Thats the first place to start
New OE wires
New OE recomended plugs
fuel filter
PCV valve
Air Filter
If there is oil on the tip of the old plug wires you will need new valve cover gaskets and seals.
Then after that if we still have an issue we will dig further.
nipper
