Advice on Installing EA82 control arms -> EA81
So I've been told in the past that to fit EA82 control arms on my EA81, I would have to relocate the inboard lower control arm mounts.
Here are the old threads: http://www.ultimatesubaru.org/forum/showthread.php?t=6197&highlight=ea81+ea82
http://www.ultimatesubaru.org/forum/showthread.php?t=7115&highlight=ea81+ea82
Anyway, now I have a spare crossmember I can start fiddling around with. Can anyone tell me, by looking at the pictures below, in what direction and how far I would have to move the mount to fit EA82 lower control arms to my EA81? I don't really see where or how the mount could be moved except inwards.
If I were doing it I would likely just shorten the control arms and also reinforce them at the same time. Kill two birds that way and don't have to mess with the x-member. Just cut out a slice in the straightest section - make it 1/8" more than what you need to remove. Then weld the two peices back together with a section of 1/8" flat bar inbetween to reinforce. Then fully box the ends for strength.
