Fuel Pump Advice
I'm getting ready to take a big trip from VA to AK about 5500 miles in my 92 loyale with 160k miles. The question I have regards the fuel pump. Once in the past year I have had to do the hit the fuel pump to make the car run trick. Does that mean the pump is ready to go sometime soon? and would you drive a 5500 mile trip with the pump or replace it?
If you question whether you need to replace a potentially
faulty fuel pump, before embarking on a 5500 mile journey,
perhaps you should consider flying instead?
Really though, replace it. Keep the old one in the trunk.
Check this out as well: http://www.ultimatesubaru.org/forum/showthread.php?t=30384&highlight=Road+trip
have a spare spfi pump in the trunk
along with spare
fuel
fuel filter
ATF
coolant
oil
oil filter
t-belts
belts
axles
starter
alternator
waterpump
lugnuts
tools
service manuals
trucker's road atlas
Alot of these parts would be much easier to change before you leave on the trip then carrying it as a spare.
nipper
I've just done t-belts and have the old ones stowed, replaced axle boots, and water pump. Drive belts are new but I'll put in a some spares they are cheep. I might look into the F-150 fuel pump and put the current one in the back. I don't have an alt but the current one is new and I carry tools, towing strap, jumper cables, repair manuals, camping gear, food water, clutch cable, and a bunch of other fluids.
My question was more, if I had to tap on the fuel pump once, does that mean its going bad?
If you have to tap an electric motor to get it moving, it has a tired bushing on a bad winding. I would replace it.
nipper
