86 ea82t trans
griz272000
Put the LSD center chunk in the 3.9 case with the 3.9 ring gear and set it up. This will leave you with the necessary parts to make a 3.7 open diff.. for what it's worth :P
is it just a matter of swapping the ring and pinion and setting it up?
does anybody know if the 4.11 in my ea82t trans 5 speed - will go into a 5 speed dual range transwith 3.90 . if so are there any special mods . i would like to get the dual range but also keep my gearing. thaanks in advance
are you in Auburn WA? if so i have a 3.7:1 DR Turbo trans i would sale for $100. it works just fine, grinds in 2nd if you go above 6000RPM when you shift...
-=Suberdave=-
