subiemech85 Posted January 17, 2004 Share Posted January 17, 2004 going to exhaust shop Saturday, need to know what size pipe to run after glasspack tired of my ears ringing from glasspack dumping behind my seat Link to comment Share on other sites More sharing options...
rallyruss Posted January 17, 2004 Share Posted January 17, 2004 um well the same size as the glass pack outlet? 2" is usually sufficient and will keep noise down a bit. Link to comment Share on other sites More sharing options...
Snowman Posted January 17, 2004 Share Posted January 17, 2004 I think I've got 2.5" on mine, and it works quite well. Link to comment Share on other sites More sharing options...
oddcomp Posted January 17, 2004 Share Posted January 17, 2004 right now i have a short short glass pack mounted all the way at the end of the exhaust where the stock muffler would be Link to comment Share on other sites More sharing options...
MilesFox Posted January 17, 2004 Share Posted January 17, 2004 if you wish, have a new center pipe made to have the glasspack after the ypipe flange, use a 2 inch bomb, and run as fat as you want pipe out the back. the ypipe will do the scavenging, the glasspack will do the backpressure, anything after that is just pure flow. Link to comment Share on other sites More sharing options...
Skip Posted January 17, 2004 Share Posted January 17, 2004 I used 2", improved both low end and top end with this setup Link to comment Share on other sites More sharing options...
subiemech85 Posted January 18, 2004 Author Share Posted January 18, 2004 problem fixed $120 later, write-up on page 5 Link to comment Share on other sites More sharing options...
