Caramanos2000 Posted March 2, 2009 Share Posted March 2, 2009 After changing a bad rotor (will be changing the other in the next few days) I get a weird vibration over 55mph. The car shakes every 2 seconds or so so its much slower than the rotation of the wheels. What could it be? Link to comment Share on other sites More sharing options...
bratman18 Posted March 2, 2009 Share Posted March 2, 2009 Caramanos2000 said: After changing a bad rotor (will be changing the other in the next few days) I get a weird vibration over 55mph. The car shakes every 2 seconds or so so its much slower than the rotation of the wheels. What could it be? loose axle nut? loose lug nuts? Link to comment Share on other sites More sharing options...
Caramanos2000 Posted March 2, 2009 Author Share Posted March 2, 2009 Checked both, castle nut is snug as a bug and hasnt moved at all. The lug nuts are also tight :-\ Link to comment Share on other sites More sharing options...
bratman18 Posted March 2, 2009 Share Posted March 2, 2009 Caramanos2000 said: Checked both, castle nut is snug as a bug and hasn't moved at all. The lug nuts are also tight :-\ Is the brake dragging? Did you twist the piston in far enough? Link to comment Share on other sites More sharing options...
ivantruckman Posted March 2, 2009 Share Posted March 2, 2009 worn axle shaft, any clicking at full turns Link to comment Share on other sites More sharing options...
troptree Posted March 2, 2009 Share Posted March 2, 2009 how are your boots on your CV joints? If they are split like mine your joints are dry & heat up at that speed - try shooting a lot of grease into all 4 joints (2 inner & 2 outer) and see if that helps - if it does then you should think about having them rebuilt (approx $100 per axle) if you are over 80,000 mi. Link to comment Share on other sites More sharing options...
Caramanos2000 Posted March 3, 2009 Author Share Posted March 3, 2009 Both axles are brand new, no clicking at all. Not sure about the brakes, they did seem to drag for the first few minutes and then it stopped and all was good. Could I still have some dragging at speed and not notice it? Wouldn't that heat up my rotors and makem smoke and what not? Link to comment Share on other sites More sharing options...
abog Posted March 3, 2009 Share Posted March 3, 2009 Is the rotor you put on out of balance and causing a harmonic vibration? Is the rotor all the way on the hub? Not crooked because of rust etc. ? Link to comment Share on other sites More sharing options...
nipper Posted March 3, 2009 Share Posted March 3, 2009 Checjk your universal joints and carrier bearing. If its a universal joint you will notice that it will drop from 55 to 50 to 45 over time. nipper Link to comment Share on other sites More sharing options...
Caramanos2000 Posted March 3, 2009 Author Share Posted March 3, 2009 It is not the rotors as it is also brand new :-\ Link to comment Share on other sites More sharing options...
naru Posted March 3, 2009 Share Posted March 3, 2009 Try installing the wheel in each of the other 3 possible positions.Wheel might have originally been balanced while on the car. Link to comment Share on other sites More sharing options...
Caramanos2000 Posted March 3, 2009 Author Share Posted March 3, 2009 Darnit think thats the issue lol. The wheels have 4 new tires but were never re-balanced lol Link to comment Share on other sites More sharing options...
bratman18 Posted March 3, 2009 Share Posted March 3, 2009 Caramanos2000 said: Darnit think thats the issue lol. The wheels have 4 new tires but were never re-balanced lol Yup that's it!! Get them rebalanced Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted March 3, 2009 Share Posted March 3, 2009 i have had a u joint go out in the driveshaft to the rear diff... not fun... it vibrated somewhat like what you said. Link to comment Share on other sites More sharing options...
naru Posted March 3, 2009 Share Posted March 3, 2009 Caramanos2000 said: Darnit think thats the issue lol. The wheels have 4 new tires but were never re-balanced lol I`d try moving it around anyway. Link to comment Share on other sites More sharing options...
abog Posted March 3, 2009 Share Posted March 3, 2009 Just because rotors are new, doesn't mean they are ok. I have run across many new ones that were not straight. If you didn't have this problem before changing this rotor, doesn't it make sense that it has something to do with the work that was done? One thing that I have also seen a lot of is rotors that dont sit flat on the hub due to rust build up , even though they are tight they are not flat on the hub. Link to comment Share on other sites More sharing options...
Caramanos2000 Posted March 4, 2009 Author Share Posted March 4, 2009 Hub had no rust on it just a little faded. The vibration around 65mph comes in pulses and it begins again with the end of the last pulse. Meaning there is no time gap. What I dont understand is why it is slower than the rotation of the tire :-\ Link to comment Share on other sites More sharing options...
TomRhere Posted March 4, 2009 Share Posted March 4, 2009 Check your ball-joints and inner/outter tie-rod ends for any play in them. New tires can cause worn parts there to show up as a vibration like you are describing. Link to comment Share on other sites More sharing options...
crash321 Posted March 5, 2009 Share Posted March 5, 2009 nipper said: Checjk your universal joints and carrier bearing. If its a universal joint you will notice that it will drop from 55 to 50 to 45 over time. nipper beat me to it:) Link to comment Share on other sites More sharing options...
Caramanos2000 Posted March 5, 2009 Author Share Posted March 5, 2009 Would some pics help you guys diagnose it? Link to comment Share on other sites More sharing options...
nipper Posted March 5, 2009 Share Posted March 5, 2009 Caramanos2000 said: Would some pics help you guys diagnose it? Your going to show us a fuzzy picture? nipper Link to comment Share on other sites More sharing options...
Caramanos2000 Posted March 5, 2009 Author Share Posted March 5, 2009 Nah I have an ok camera lol no cell phone crap Link to comment Share on other sites More sharing options...
nipper Posted March 5, 2009 Share Posted March 5, 2009 Caramanos2000 said: Nah I have an ok camera lol no cell phone crap Sheesh my humor is just failing all over the place. I thought you offered to take a picture of the vibration Link to comment Share on other sites More sharing options...
Caramanos2000 Posted March 8, 2009 Author Share Posted March 8, 2009 Oh rofl lol well I could, for a small fee of course:banana: Issue resolved: wheels balanced and rotated... DUH:rolleyes: Link to comment Share on other sites More sharing options...
