EA82 Springs
Hmmm, I just wonder if it's ok to put 2WD springs on 4WD struts.
I'd say yes. I can't see there being "that" much difference, if any in the spring rates.
A big plus would be if the springs you use are lower mileage/newer. That will affect the spring rates. If they have 300 K on them, they're prolly toast anyway.
Doug
Someone posted a chart here once about that. I cant find it now but if memory serves me the spring rates are way different. The 2wd has a lower spring rate. Its like 145lbs to 125lbs for the 2wd. My 82' wagon has the 4wd coilovers and it bounces when the rear is empty :eek: (I have no rear seats) but it drives like a loyale with a full load of tools in the back. :banana:
Fortunately I drive with a load most often.
The spring rates are 196 for both...... Makes sense. Hmm, well I look funny too!:lol: Maybe I was looking at the legacies. No wonder I bounce! Is there a chart, say, for ea81s and what they are supposed to be?
The stock springs on my 92 loyale are real soft, rides nice but the taller snow tires will rub on a good bump. I put rear struts from a 2wd wagon on the rear and I have no problems back there anymore. The springs were a larger diameter, I think 1mm more. So there are different springs out there. it looks like I need RX springs for the front..
I've owned both, 2wd and 4wd, and the 4wd's were a stiffer ride.
Edited by Frank B
