I searched: Drill bit size for drilling wheels?
What size drill bit have people been using when drilling 6-lug wheels to Subaru's 4-lug pattern? I used a 35/64 bit, and I have a hard time getting the wheels back off the hub. I'd like to go to a bigger bit, but I don't know how big would be too big.
Thanks.
Jacob
  lostinthe202 said:
Are you sure your holes are in the right place? If they aren't and you keep making the holes bigger until they fit, then you'll end up with studs that are not centered in the hole which could be a problem.
Yeah, I feel pretty good about the holes being in the right place. The wheel just kept getting stuck taking it off last night. A slightly wider hole shouldn't be a problem, but I definitely don't want these things slipping off.
Jacob
  monstaru said:
use a 9/16 to drill wheels....
you use a 35/64ths to drill hubs......
and yes the bevel degree is 60 for the countersink,at least that is what i used.
cheers, brian
I didn't see this, that's your problem. Drill them out with a 9/16ths
