heater not hot enough :(
i have an 81 wagon and my heater doesnt seem to get hot enough for my tastes. now take into account that im a guy who does snow camping and rides a motorcycle every day of the year that there isnt snow on the ground so im no stranger to the cold.
the heater does get warm and blows air it just doesnt get hot enough when its below 32 outside.
is there anything i can do to spiff up the heater?
This was also happening to me in my '81. However I have a rew rad., new heater core, and blend doors were all adjusted properly. I just replaced the thermostat and all is well. It heats up proper now. These cars pump out the heat when working properly, so there is no reason not to be warm enough.
Obviously check the heater core through the heater hose temperature difference and the blend door cable, but if you haven't changed the thermostat or have an aftermarket one in there I would just change it out anyway. The thermostat is a part that should be bought at the dealer. There is a huge difference in quality and performance between SOA and aftermarket. I just got mine from Lithia in Oregon City recently for ~$19 with gasket. They had them in stock, also pick up a PCV valve while your there, also in stock ~$9.
I had the same problem with very little heat at any speed except idle. I flushed the heater core & radiator with a garden hose & replaced the mcparts thermostat with a Subaru one. Now there's plenty of heat :)
Buy one of the "hose menders" at harbor freight for a dollar to hose clamp the garden hose onto each heater core hose.
Just get a 54mm 220 Degree thermostat... that should raise the temp of your heat inside the car.... as well as the temp of your engine Just enough that it might blow a head gasket.
What I'm saying is that you may have a problem such as a bad water pump, a clogged radiator/heater core. and/or a partially functioning Thermostat. Don't ************ around. Get it fixed Flushing it just runs the risk of pushing the clog into the engine and clogging it... the coolant passages get pretty small....
Or do What I do... Everytime I get a questionable car... I replace the entire cooling system.
You replace the entire cooling system? even the Heater core?
Way more than needed.
If you disconnect the heater core from the engine at both hoses, there is no risk of spushing anything into the radiator or engine.
It might be that your ductwork is loose and allowing air to escape.
Check under the passenger side dashboard.
If its the same as my brat, there will be a black tube that air blows through.
It should run from the outer panel to the center of the dash.
If that's not the problem then, as everyone else said,
try cleaning your heater core and your radiator.
Twitch
