bicycle_ben Posted March 7, 2009 Share Posted March 7, 2009 i have an 81 wagon and my heater doesnt seem to get hot enough for my tastes. now take into account that im a guy who does snow camping and rides a motorcycle every day of the year that there isnt snow on the ground so im no stranger to the cold. the heater does get warm and blows air it just doesnt get hot enough when its below 32 outside. is there anything i can do to spiff up the heater? Link to comment Share on other sites More sharing options...
subiemech85 Posted March 7, 2009 Share Posted March 7, 2009 reseal airbox search freeze burn seat insulated heater hose move to where it is warmer :-p Link to comment Share on other sites More sharing options...
The Scooby Posted March 7, 2009 Share Posted March 7, 2009 ^gee that was alot of help... i would make sure that your blend door is working properly. its common on the EA81's that the cable will slip and it just push luke warm air. Link to comment Share on other sites More sharing options...
ihscout54 Posted March 7, 2009 Share Posted March 7, 2009 Is the car running at operating temp? If the car isnt heating up the heater wont either. Do you know what temp thermostat you are running? Link to comment Share on other sites More sharing options...
akc Posted March 7, 2009 Share Posted March 7, 2009 heater core? Link to comment Share on other sites More sharing options...
ihscout54 Posted March 7, 2009 Share Posted March 7, 2009 Thats an easy one to test. If the inlet side is hot, and the outlet side is quite a bit cooler its plugged up. Link to comment Share on other sites More sharing options...
ferox Posted March 7, 2009 Share Posted March 7, 2009 This was also happening to me in my '81. However I have a rew rad., new heater core, and blend doors were all adjusted properly. I just replaced the thermostat and all is well. It heats up proper now. These cars pump out the heat when working properly, so there is no reason not to be warm enough. Obviously check the heater core through the heater hose temperature difference and the blend door cable, but if you haven't changed the thermostat or have an aftermarket one in there I would just change it out anyway. The thermostat is a part that should be bought at the dealer. There is a huge difference in quality and performance between SOA and aftermarket. I just got mine from Lithia in Oregon City recently for ~$19 with gasket. They had them in stock, also pick up a PCV valve while your there, also in stock ~$9. Link to comment Share on other sites More sharing options...
bicycle_ben Posted March 7, 2009 Author Share Posted March 7, 2009 the needle on the dash comes all the way up to the line for normal operating temp but who knows how accurate that poor thing is. ill take apart the blender goodness on my weekend and see what all is going on in there. Link to comment Share on other sites More sharing options...
The Dude Abides Posted March 7, 2009 Share Posted March 7, 2009 All this just reminds me i need to go through my cooling system this summer. Mine just takes forever to warm up and when it does it doesnt seem to defrost the front window very well. Ive got lots to check. Good Luck. Link to comment Share on other sites More sharing options...
henrysteele77 Posted March 11, 2009 Share Posted March 11, 2009 try flushing your heater core . disconnect heater hoses, run water from garden hose through them, switch back and forth. you will be supprised what comes out. made a huge differance on several of my cars! Link to comment Share on other sites More sharing options...
NoahDL88 Posted March 11, 2009 Share Posted March 11, 2009 Make sure you have enough coolant, if you don't the heater core won't fill with fluid Link to comment Share on other sites More sharing options...
derburger Posted March 11, 2009 Share Posted March 11, 2009 I had the same problem with very little heat at any speed except idle. I flushed the heater core & radiator with a garden hose & replaced the mcparts thermostat with a Subaru one. Now there's plenty of heat Buy one of the "hose menders" at harbor freight for a dollar to hose clamp the garden hose onto each heater core hose. Link to comment Share on other sites More sharing options...
xoomer Posted March 16, 2009 Share Posted March 16, 2009 Just get a 54mm 220 Degree thermostat... that should raise the temp of your heat inside the car.... as well as the temp of your engine Just enough that it might blow a head gasket. What I'm saying is that you may have a problem such as a bad water pump, a clogged radiator/heater core. and/or a partially functioning Thermostat. Don't ************ around. Get it fixed Flushing it just runs the risk of pushing the clog into the engine and clogging it... the coolant passages get pretty small.... Or do What I do... Everytime I get a questionable car... I replace the entire cooling system. Link to comment Share on other sites More sharing options...
Gloyale Posted March 16, 2009 Share Posted March 16, 2009 xoomer said: Just get a 54mm 220 Degree thermostat... that should raise the temp of your heat inside the car.... as well as the temp of your engine Just enough that it might blow a head gasket. What I'm saying is that you may have a problem such as a bad water pump, a clogged radiator/heater core. and/or a partially functioning Thermostat. Don't ************ around. Get it fixed Flushing it just runs the risk of pushing the clog into the engine and clogging it... the coolant passages get pretty small.... Or do What I do... Everytime I get a questionable car... I replace the entire cooling system. You replace the entire cooling system? even the Heater core? Way more than needed. If you disconnect the heater core from the engine at both hoses, there is no risk of spushing anything into the radiator or engine. Link to comment Share on other sites More sharing options...
xoomer Posted March 17, 2009 Share Posted March 17, 2009 Yep actually I do. did that in my old xt6, last year... and that stuff is comming with me to my new xt6.... and I'm doing the same thing to my legacy as we speak Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted March 17, 2009 Share Posted March 17, 2009 It might be that your ductwork is loose and allowing air to escape. Check under the passenger side dashboard. If its the same as my brat, there will be a black tube that air blows through. It should run from the outer panel to the center of the dash. If that's not the problem then, as everyone else said, try cleaning your heater core and your radiator. Twitch Link to comment Share on other sites More sharing options...
