legacyak Posted March 8, 2009 Share Posted March 8, 2009 Does anybody know the diameter for the front discs on a 2000 OBW? I have had several sets of rotors that have not been the correct diameter. This causes a ridge to build up on the pads and vibrations when braking. Does anybody know the factory diameter of the front discs??? Link to comment Share on other sites More sharing options...
Rooster2 Posted March 8, 2009 Share Posted March 8, 2009 Does anybody know the diameter for the front discs on a 2000 OBW? I have had several sets of rotors that have not been the correct diameter. This causes a ridge to build up on the pads and vibrations when braking. Does anybody know the factory diameter of the front discs??? hmmm.....I always thought it was normal for a ridge to build up as the brake pads wear down the rotors. I just throw on another set of pads when they are worn out, and live with the ridge. However, if the rotors get really worn down, and the ridge is substantial, then I simply replace the rotors. I don't think the diameter size of the rotors is an issue, unless you think your present rotors are some how the wrong size. Link to comment Share on other sites More sharing options...
legacyak Posted March 10, 2009 Author Share Posted March 10, 2009 Just for the record, it is 10.9 inches. Link to comment Share on other sites More sharing options...
Legacy777 Posted March 17, 2009 Share Posted March 17, 2009 I've got a lot of that info in my brake math spreadsheet. Go to the brake data tab. http://www.main.experiencetherave.com/subaru/techinfo/brakemath.xls Link to comment Share on other sites More sharing options...
MtTech Posted March 17, 2009 Share Posted March 17, 2009 Nice.... more info than I would ever need to know! Would you happen to know specs on 2006-2008 legacy and Impreza as well? mt Link to comment Share on other sites More sharing options...
Legacy777 Posted March 23, 2009 Share Posted March 23, 2009 The legacy should be the same as the 05 info. The impreza has the 4-pot & 2-pot's for the WRX. The rest should be same. Link to comment Share on other sites More sharing options...
