Note to self. Live and learn.
After mechanic installs new racing clutch.... DO NOT ADJUST IT YOURSELF, EVER!
The SPEC stage 2 was to be, but will not be the last clutch I buy.
After less than 60,000 miles this one is DUN! Racing clutches are touchy, BUT strong. They don't last long when out of adjustment though.
Once its installed and adjusted by the pro, leave it alone, no matter how much you want to learn and fiddle with things....
Lesson learned.
Now, with the need for another flywheel to go with my Exedy replacement, I will be back on the road tomorrow...
AND I WILL NOT TOUCH CLUTCH OR HILL-HOLDER ADJUSTMENTS AGAIN :)
Edited by superu
added info
What makes you think a racing clutch should last even half of that? Clutches are no different from brakes. The crappy ones don't grab well but last forever. Good ones grab really well and wear fast. Combine that with the type of aggresive driving that would require an upgraded clutch and it wears even faster. I would personally say that you got WAY more life out of that clutch than you should have expected.
Keith
Keith
Agreed.
nipper
Keith
Yeah, wear items are wear items, but i thought that a clutch speced for racing would be overkill for a daily driver and occasional light offroading and pulling (i.e. pulling cars out of the snow ;)
I guess i was sold by the SPEC specs indicated extra long life, and by the guy at clutchexpress. I was under the impression it would be an excellent choice for long life (as a daily driver) but MUCH stonger than stock when applied for pulling, and light offroading. :confused:
So if i got 60K out of it, and that's long for a stage 2, though not used in a racing application, i guess i feel a touch better about it... Still nearly 5 bills for a clutch gone in 4 years... Hopefully the "OEM" exedy will outlast the original Suby clutch (which went 110K) :)
But, ya live and ya learn! :-\
