Uberoo Posted March 11, 2009 Share Posted March 11, 2009 I just bought a brand new clutch kit for my 84 subaru wagon with the 4 speed DR 4x4 transmission.I cant seem to adjust the clutch to where I can actually get the gears.I can find reverse only because it grinds.I cant find the other gears at all.I can put the car in gear then start it up and the car still tries to go forward even with the clutch fully pressed.The adjustment nut only has maybe 1/8 of an inch before it runs out of threads.How do I adjust this stupid thing so it will go into gear without grinding or having the throwout bearing whirr on the pressure plate? Link to comment Share on other sites More sharing options...
ihscout54 Posted March 12, 2009 Share Posted March 12, 2009 Out of threads towards the cable right? (tightening it) Sounds like you know what you are doing. Are you sure the flywheel is in spec? also this shouldnt apply here but... I went through this on my brat when I swapped the D/R for a S/R. There are a few styles of clutch out there and one of them has almost 1/4" difference in spacing somewhere in the P.P. I had to use a different clutch. Specs call for 1/2" play in the pedal, if your pedal is badly worn to a nice slot or the cable attatchment is screwed up you may be loosing alot of clutch pedal there. Link to comment Share on other sites More sharing options...
Uberoo Posted March 12, 2009 Author Share Posted March 12, 2009 with the pedal I have like 1/2 the travel before I feel any resistance. Link to comment Share on other sites More sharing options...
subiemech85 Posted March 12, 2009 Share Posted March 12, 2009 seems to me you "adjusted" it the WRONG WAY screw on the nut TOWARDS the LEVER until there is almost no wiggle room when moving the lever front and back be sure the cable is pulled thght while doing this if excessively tight, it will either slip or not catch at all, or engage adbruptly at the TOP of pedal travel, opposite of your problem Link to comment Share on other sites More sharing options...
Uberoo Posted March 12, 2009 Author Share Posted March 12, 2009 so do I adjust the nut towards or away from the front of the car? Link to comment Share on other sites More sharing options...
subiemech85 Posted March 12, 2009 Share Posted March 12, 2009 re-read what I posted^ away Link to comment Share on other sites More sharing options...
Uberoo Posted March 12, 2009 Author Share Posted March 12, 2009 that is what I did. Link to comment Share on other sites More sharing options...
ihscout54 Posted March 12, 2009 Share Posted March 12, 2009 So you have adjusted it till the t.o. bearing drags and it still wont fully release? Then you have a problem beyond adjustment. Bent fork improper components etc... You might pop that pedel out and take a look at the linkage wear. Do you have the pn. # for the clutch kit you used? You did use a kit and replace all components correct? Link to comment Share on other sites More sharing options...
Uberoo Posted March 12, 2009 Author Share Posted March 12, 2009 beck arney 061-9131 I bought the car with a blown clutch.The throwout bearing wore almost all the way through the pressure plate,the disk was shot but the studs wernt touching the flywheel yet.I am thinking that the clutch cable went south as well because if I pull on the cable this white lining comes out. Link to comment Share on other sites More sharing options...
ivantruckman Posted March 12, 2009 Share Posted March 12, 2009 the clutch cable could have stretched as well Link to comment Share on other sites More sharing options...
ihscout54 Posted March 12, 2009 Share Posted March 12, 2009 Thats a possibility but thats alot of stretch, there would have to be more going on than just that I'de think. But its worth a try. Link to comment Share on other sites More sharing options...
Uberoo Posted March 13, 2009 Author Share Posted March 13, 2009 Ihscout54 does your user name mean international scout? If so could you post pics?If not I am just crazy... Link to comment Share on other sites More sharing options...
ihscout54 Posted March 13, 2009 Share Posted March 13, 2009 Ive had 5 IH's: 4 scouts 1 truck, its been years since I sold them, all but one, and its a basket case sitting in another state. I wish I still had all of them but things in life change money gets tight and gas breaks $3.50 a gallon. Then one day no scouts. Subaru's fill the void for now. A scout is the only thing I'de give up my brat for. Link to comment Share on other sites More sharing options...
Uberoo Posted March 13, 2009 Author Share Posted March 13, 2009 neat.scouts are cool but i was always told to stay away from them because of parts availbitity. not sure if thats true though... Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted March 13, 2009 Share Posted March 13, 2009 the clutch cable could have stretched as well ...and when it Happens, it is About to Break! ... ... I Suggest you to obtain another Clutch Cable and carry it in the Trunk... Link to comment Share on other sites More sharing options...
