Blew The HG
I dont know if i did this but drove my green turd 20 miles home today. I kept getting it to the H point on the Gauge then shut her down. Did this for a while untill i finally got her home. No steam coming out the pipe, no loss of coolant but it boiled over. Probally a stuck t-stat. I might just pull it out and run it open for whoever buys it. I guess my only concern is that i did it for so long i dont know if i cooked it or not. Your thoughts please.
Maybe it has a Blown Hose, the Usual one who Blows First on EA82`s is the 90º Degrees 5/8" Hose that Comes from the Water Pump`s Upper side, Turning over the Engine and Connecting to the Heather Pipes...
Because its Location, it usually is not Checked too Often...
I Suggest you to Check Everything Related to the Coolin` System, fix the Needed, and Try to Drive your Subie Again... Maybe the Head Gaskets are Fine.
...I wouldnt run my car with out a t-stat.
I Believe that is Due to your Area`s Climates, isn`t it?
All my Cars are Runnin` Fine Without Thermostat for Many Years and seems like this Keeps the Coolin` System more Healthy; but I Live in the Tropical Caribbean... (No Snow nor Salty Roads here, But our Roads Sucks) ...and the Temp Gauge Barely Reaches 1/4 in normal Driving Conditions.
It has been my experience that EA82 + overheat due to coolant loss = new headgaskets. Even one time. Maybe immediately, maybe in a number of months.
In the milder one time cases, I put up with coolant seeping from the HG for many months.
Milder case = last 1/2 mile to house, noticed the gauge a little high, found a pinhole in one of the small hoses spraying out coolant.
