86subaru Posted March 15, 2009 Share Posted March 15, 2009 check engine light came on , checked with code reader, catalyst effeciency below threshold, below bank 1, car runs fine, mpg 24-25 city, did a search front o2 sensor , headers, etc... any opions, ??? also my wife may not have put gas cap on tight enough , Link to comment Share on other sites More sharing options...
OB99W Posted March 15, 2009 Share Posted March 15, 2009 Start here: http://www.motor.com/magazine/pdfs/102006_09.pdf Link to comment Share on other sites More sharing options...
lmdew Posted March 15, 2009 Share Posted March 15, 2009 Clear the code and see if it comes back. If it does, check or replace the front O2 sensor with a Subaru Part. Many times that will fix it. I take it you have done normal maintenance, NGK Plugs, Subaru Plug Wires.... Good Luck. Link to comment Share on other sites More sharing options...
EVOthis Posted March 15, 2009 Share Posted March 15, 2009 for future reference...Gas cap being let loose/off will not throw this code...Chances are it would set an EVAP leak code... Link to comment Share on other sites More sharing options...
86subaru Posted March 15, 2009 Author Share Posted March 15, 2009 i have not changed the plugs or wires since i bought it, 38,000mi ago, ok on the gas cap losse code, yes i cleared the code , i do have a subaru o2 sensor [ new] sitting in abox , thanks, Link to comment Share on other sites More sharing options...
