Rear strut question
Yes but No, Let me Explain:
2WD Models` Struts have the Base Plate for the Spring Coil, Welded Two inches Lower than the 4WD Models` Struts...
So Yes: They will Fit Perfectly but No, You may not Use a 2WD Strut in one side while there is a 4WD Strut in the Other Side... I Suggest to Find the 4WD one, or Change `em Both with the 2WD ones...
Good Luck!
