hebrewhammer Posted March 15, 2009 Share Posted March 15, 2009 going to do a full re-seal and change out the front input bearing in my 5MT. What are the torque specs for the bolts on the case, or any critical bolt torque specs. I have read the writeup on it. Any other helpfull tips? Link to comment Share on other sites More sharing options...
Legacy777 Posted March 17, 2009 Share Posted March 17, 2009 bump Link to comment Share on other sites More sharing options...
EVOthis Posted March 17, 2009 Share Posted March 17, 2009 http://www.ultimatesubaru.org/forum/showthread.php?t=90182&highlight=input+shaft+seal Was this the thread you read?...I thought this was a great tutorial...The only thing i can tell you about the bolts on the case is this....i have personally never done this job but i have done countless viscous couplers by pulling the tailhousing off...as for the torque spec ive never really looked one up...for the 14mm's that hold on the tailhousing I just use my 3/8 impact and snug them up...have never had a comeback from one yet...knock on wood...hope this helps....good luck with the job... Link to comment Share on other sites More sharing options...
johnceggleston Posted March 17, 2009 Share Posted March 17, 2009 i think it's in the 28 - 32 ft lb range, but i don't have my haynes manual with me so you will need to double check that. also, at least one is really tough to get to with a torque wrench so i just matched it by feel to the ones i torqued. you can always go back and tighten them, but it's a real b!tch if you strip one out. Link to comment Share on other sites More sharing options...
