Uberoo Posted March 16, 2009 Share Posted March 16, 2009 Is there a way to weld the rear diff without removing it from the car?I would like to weld mine tommarow but I am not really looking forward to pulling the diff.. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted March 16, 2009 Share Posted March 16, 2009 Is there a way to weld the rear diff without removing it from the car?I would like to weld mine tommarow but I am not really looking forward to pulling the diff.. Ive done it on a Jeep , just remove the rear cover and weld it up, problem will be getting it all cleaned out when your done, Link to comment Share on other sites More sharing options...
Turbone Posted March 16, 2009 Share Posted March 16, 2009 And dont forget, the gas tank is right above your head And you will need about 6-7 cans of brake cleaner too. Link to comment Share on other sites More sharing options...
bheinen74 Posted March 16, 2009 Share Posted March 16, 2009 the fact that the gas tank is so near, welding sparks a flying, and the fact it will have gear oil there, and the making sure you get all the welding slag and whatnot cleaned out, i would say remove the thing first. You have to make sure there is no little slivers of anything left behind in there. Link to comment Share on other sites More sharing options...
ezapar Posted March 16, 2009 Share Posted March 16, 2009 What's it take, 15 minutes to pull a diff? 2 axle pins, a 22, two 17s, and 4 12s. Link to comment Share on other sites More sharing options...
TeamCF Posted March 16, 2009 Share Posted March 16, 2009 I'd say just pull it. Easier. Safer. And besides if you want to leave it in. You will have to pull the mustache bar anyway in order to remove the back cover. So you may as well just pull the diff instead and call it good. They pop in and out pretty easy. Link to comment Share on other sites More sharing options...
monstaru Posted March 16, 2009 Share Posted March 16, 2009 i've got a 3.9 already done .you want it?25 bucks you come get it.cheers, brian Link to comment Share on other sites More sharing options...
bheinen74 Posted March 16, 2009 Share Posted March 16, 2009 somebody should make a "locker" setup, something that can be pushed into the spider gears to lock it, and can be removed to unlock. This device would be on a spring loaded pin system accessed from the side of the case or the rear cover plate. Push the pin in, and it locks the diff. pull the pin outward and its open again. just a thought. Link to comment Share on other sites More sharing options...
monstaru Posted March 16, 2009 Share Posted March 16, 2009 have you ever searched for locker on this board?it has been talked about for years and years.and even looked into by engineers,machinist and the like.hell, i think a rocket scientist or two may have looked into it as well.and i am not joking. it comes down to the same thing every time.money, money, money.oh, and money. but i think you could do it.tell us when you have it figured out.i personally can't wait.:)cheers, brian somebody should make a "locker" setup, something that can be pushed into the spider gears to lock it, and can be removed to unlock. This device would be on a spring loaded pin system accessed from the side of the case or the rear cover plate. Push the pin in, and it locks the diff. pull the pin outward and its open again.just a thought. Link to comment Share on other sites More sharing options...
bheinen74 Posted March 16, 2009 Share Posted March 16, 2009 this will require lots of Guinness to get me thinking Link to comment Share on other sites More sharing options...
frogstar7055 Posted March 16, 2009 Share Posted March 16, 2009 have you ever searched for locker on this board?it has been talked about for years and years.and even looked into by engineers,machinist and the like.hell, i think a rocket scientist or two may have looked into it as well.and i am not joking. it comes down to the same thing every time.money, money, money.oh, and money. but i think you could do it.tell us when you have it figured out.i personally can't wait.:)cheers, brian It's easy,retrofit an R200 with an ARB e-locker. Fab up new mounts and shafts. Install and flick the switch. Only around $1500-$2000 (guesstimate). Link to comment Share on other sites More sharing options...
bratman18 Posted March 16, 2009 Share Posted March 16, 2009 only Link to comment Share on other sites More sharing options...
monstaru Posted March 17, 2009 Share Posted March 17, 2009 (edited) if it is so easy,why are you not doing it in your forrester then?:)thats what i thought....... oh, and we were talking about modifying the r160..........so no, not easy.. It's easy,retrofit an R200 with an ARB e-locker.Fab up new mounts and shafts. Install and flick the switch. Only around $1500-$2000 (guesstimate). Edited March 17, 2009 by monstaru Link to comment Share on other sites More sharing options...
Uberoo Posted March 17, 2009 Author Share Posted March 17, 2009 well I didnt get the diff welded today. someone ran off with my tools.or at least all of the tools that I needed, like a 3/16 punch, any metric socket or wrench larger than 15mm,and beer.So I suppose I will just do it at my buddies shop before we go play on thursday...I have to go there anyway to get the rest of my tractor tires... Link to comment Share on other sites More sharing options...
frogstar7055 Posted March 17, 2009 Share Posted March 17, 2009 if it is so easy,why are you not doing it in your forrester then?:)thats what i thought....... oh, and we were talking about modifying the r160..........so no, not easy.. He asked about a locker. R-200 is the ONLY way your gonna put a real locker in a Subaru. Nobodies gonna make one for an R-160,too weak and not enough interest to produce one. And as for doing a R-200 in my Forester it would be easy for me except for the $$$$$$$$. Link to comment Share on other sites More sharing options...
monstaru Posted March 17, 2009 Share Posted March 17, 2009 you just said it,in a different way than i did?huh....... and it is possible to get a locker for the r180....they are just out of production.if someone had one lyin around.that would be easy too.......so it is not the ONLY way. everything can be easier with money....cheers, brian He asked about a locker.R-200 is the ONLY way your gonna put a real locker in a Subaru. Nobodies gonna make one for an R-160,too weak and not enough interest to produce one. And as for doing a R-200 in my Forester it would be easy for me except for the $$$$$$$$. Link to comment Share on other sites More sharing options...
bheinen74 Posted March 17, 2009 Share Posted March 17, 2009 who holds winning lottery ticket? can has locking rear diff Link to comment Share on other sites More sharing options...
frogstar7055 Posted March 17, 2009 Share Posted March 17, 2009 you just said it,in a different way than i did?huh....... and it is possible to get a locker for the r180....they are just out of production.if someone had one lyin around.that would be easy too.......so it is not the ONLY way. everything can be easier with money....cheers, brian Who makes a locker for the R-180? I've run across a couple of them in my wanderings,should have picked one up. Link to comment Share on other sites More sharing options...
Turbone Posted March 17, 2009 Share Posted March 17, 2009 It would probably be cheaper and easier to go with a straight axle and install a electric locker in that. Gee, I wonder who did that? (No, it wasnt me) Link to comment Share on other sites More sharing options...
frogstar7055 Posted March 17, 2009 Share Posted March 17, 2009 It would probably be cheaper and easier to go with a straight axle and install a electric locker in that. Gee, I wonder who did that? (No, it wasnt me) Not looking to mod it that much (although I've considered it). Really want to retain as much of the drivetrain as possible,just want to take it as far as I can. Thought about welding the rear diff and fabbing up a wheel locker on one side so a rear wheel could be disconnected on street (still considering that one). Link to comment Share on other sites More sharing options...
monstaru Posted March 18, 2009 Share Posted March 18, 2009 arb manufactured one at one point.but no more, at least not available in the US anymore...would have to find one used.cheers, brian Who makes a locker for the R-180?I've run across a couple of them in my wanderings,should have picked one up. Link to comment Share on other sites More sharing options...
tree18is Posted March 18, 2009 Share Posted March 18, 2009 well like stated above, the roo's have the mustache bar that has to come off. I know on BMW's which is where im from, we just pop the cover off. one can of brake cleaner to get the gear oil off, weld it up, once can of brake cleaner to clean it all out.. some 80-90 and your on your way to some autozone lifetime warranty axles.. Link to comment Share on other sites More sharing options...
subieman666 Posted March 19, 2009 Share Posted March 19, 2009 okay, i agree that there should be a manufactored locker for soobs somewhere out there in tv land. too bad a spool wouldn't fit in it, but wait what all goes into a spool. couldn't we make one somehow??? i am gonna look into spools,if i could get my hands on a blue print of a couple different soob rear ends and then an autocad program i could possible come up with something. Link to comment Share on other sites More sharing options...
The Scooby Posted March 19, 2009 Share Posted March 19, 2009 if i remember correctly Cusco makes a 1, 1.5, and 2 way clutch LSD, but you are looking at $1200 + for it. so if you really want one you can have one but at a cost for then the car is probably worth. Link to comment Share on other sites More sharing options...
Uberoo Posted March 19, 2009 Author Share Posted March 19, 2009 Could always try an axle disconect. with a welded diff.Like this drawing I made along time ago shows: http://s109.photobucket.com/albums/n45/Uberoo/Subaru%20stuff/?action=view¤t=axledisconnect.jpg Link to comment Share on other sites More sharing options...
