1bignose Posted March 16, 2009 Share Posted March 16, 2009 awd a/t the rear tires dont want to kick in. was in the snow you will sit there spining and when the rear tires deside kick in makes a nice loud clonk then they work or on a wet road it dose the same thing more gas you give it less noise it makes. is there a way to fix it or should i look for a new trans thanks dennis Link to comment Share on other sites More sharing options...
2.5GL Posted March 16, 2009 Share Posted March 16, 2009 This could be a multiple systems failure... Solenoid "C", worn transfer clutch packs, bad seal on shaft allowing fluid to pass, not building pressure. All could be fixed at the same time... Leaving the trans in the car too. See: http://www.ultimatesubaru.org/forum/showthread.php?t=78467&highlight=torque+bind Yes, it refers to torque bind, which you have the opposite of. The steps involved to repair are similar. Link to comment Share on other sites More sharing options...
Gloyale Posted March 16, 2009 Share Posted March 16, 2009 2 words. Lock Switch It is probably just really worn clutches. Happens. Try 1st gear starts, is it the same? Also fresh good fluid could help. If you just want quick dirty 4wd, a switch on the C solenoid wire to disconnect it will send full pressure to the clutches and lock even worn ones. Link to comment Share on other sites More sharing options...
1bignose Posted March 17, 2009 Author Share Posted March 17, 2009 got her fixed thanks Gloyale for everything and for the other post dennis:banana: Link to comment Share on other sites More sharing options...
vincentmoy Posted March 17, 2009 Share Posted March 17, 2009 1bignose said: got her fixed thanks Gloyale for everything and for the other postdennis:banana: How did you fix it? Link to comment Share on other sites More sharing options...
Gloyale Posted March 17, 2009 Share Posted March 17, 2009 2 words Lock Switch Link to comment Share on other sites More sharing options...
