mcttexan Posted March 16, 2009 Share Posted March 16, 2009 Where can I find a vent visor to fit the front window ofmy 89 suby gl 10 turbo? Dealership said it would have to be aftermarket... Any thoughts? Link to comment Share on other sites More sharing options...
wallaby Posted March 16, 2009 Share Posted March 16, 2009 Try a aftermarket truck shop - one that sells bedliners, nerf bars etc brands wound be auto ventshade (AVS) or weathershield but those shops have access to databases for cars as well as pickups Link to comment Share on other sites More sharing options...
Turbone Posted March 16, 2009 Share Posted March 16, 2009 You need a complete window frame to install a vent visor. How do you expect to attach it? Link to comment Share on other sites More sharing options...
4WDFrenzy Posted March 17, 2009 Share Posted March 17, 2009 You need a complete window frame to install a vent visor.How do you expect to attach it? I'm sorry, but this is not correct. The 1995 Subaru Legacy that I just junked had vent visors and it didn't have window frames. It(the ventvisor) attaches with small metal clips that are mounted between the A pillar and the weatherseal. The bottom portion has small screw holes(comes with screws) that the bottom portion attaches to. Double-sided tape secures the upper portion to the body of the vehicle and creates a water tight seal so that water can't seep through and sneak attack you(Drip, Drip....what the?) while you have your windows cracked. I hope that that clarifies this. -Patrick Link to comment Share on other sites More sharing options...
SoobieDoo Posted March 18, 2009 Share Posted March 18, 2009 I'm sorry, but this is not correct. The 1995 Subaru Legacy that I just junked had vent visors and it didn't have window frames. It(the ventvisor) attaches with small metal clips that are mounted between the A pillar and the weatherseal. The bottom portion has small screw holes(comes with screws) that the bottom portion attaches to. Double-sided tape secures the upper portion to the body of the vehicle and creates a water tight seal so that water can't seep through and sneak attack you(Drip, Drip....what the?) while you have your windows cracked. I hope that that clarifies this. -Patrick Any idea if the leggy's would fit a GL? I know they're both frameless, but could be different shape/profile? It's a little wet here, so I need some...even if custom! Link to comment Share on other sites More sharing options...
4WDFrenzy Posted March 19, 2009 Share Posted March 19, 2009 Any idea if the leggy's would fit a GL? I know they're both frameless, but could be different shape/profile? It's a little wet here, so I need some...even if custom! It is possible that they could fit, but how well the fit would be is my chief concern. Link to comment Share on other sites More sharing options...
SoobieDoo Posted March 19, 2009 Share Posted March 19, 2009 I'll just have to compare them side by side. Link to comment Share on other sites More sharing options...
r81gsr95 Posted September 19, 2011 Share Posted September 19, 2011 anyone ever manage to find some window visors? Link to comment Share on other sites More sharing options...
