mike97 Posted March 18, 2009 Share Posted March 18, 2009 how do you know if there bad .is there a way to check? Link to comment Share on other sites More sharing options...
davebugs Posted March 18, 2009 Share Posted March 18, 2009 Look for it visually broken - it's just heavy plastic. There are some rubber inserts IIR. You may want to check them for wear. I don't bother saving these when I part out a car. Recently I had to buy one for the rear - 45 bucks. I saved one off the last parts car! Link to comment Share on other sites More sharing options...
mike97 Posted March 18, 2009 Author Share Posted March 18, 2009 how will the car act if there bad? Link to comment Share on other sites More sharing options...
nipper Posted March 19, 2009 Share Posted March 19, 2009 Its is very obvious to see if it is broken. It may rattle when broken. You may not notice it untill you hit a really big crosswind or an emergency manuver. nipper Link to comment Share on other sites More sharing options...
davebugs Posted March 19, 2009 Share Posted March 19, 2009 Its is very obvious to see if it is broken. It may rattle when broken. You may not notice it untill you hit a really big crosswind or an emergency manuver. nipper What Nipper said. It will act like a broken swaybar on one side. ( I think I can see the next question coming). Link to comment Share on other sites More sharing options...
nipper Posted March 19, 2009 Share Posted March 19, 2009 What Nipper said. It will act like a broken swaybar on one side. ( I think I can see the next question coming). Link to comment Share on other sites More sharing options...
mike97 Posted March 19, 2009 Author Share Posted March 19, 2009 :banghead:if you guys know the next question ..please just anser .. Link to comment Share on other sites More sharing options...
mike97 Posted March 19, 2009 Author Share Posted March 19, 2009 does it clunk bang every time you hit a bump and then when your going down the highway it just doesent feel right like it sways a little ?..this is a yes or no ? Link to comment Share on other sites More sharing options...
mike97 Posted March 22, 2009 Author Share Posted March 22, 2009 yep its the end links .i had a freind push the car up and down and side to side and yes they are bad . Link to comment Share on other sites More sharing options...
EVOthis Posted March 23, 2009 Share Posted March 23, 2009 does it clunk bang every time you hit a bump and then when your going down the highway it just doesent feel right like it sways a little ?..this is a yes or no ? This could also be worn/damaged trailing arm bushings.... Link to comment Share on other sites More sharing options...
mike97 Posted March 23, 2009 Author Share Posted March 23, 2009 its in the front ..in the back I got to to do the struts I can hear them squeak when I higt a bump just right.i checked all the springs and there all good . Link to comment Share on other sites More sharing options...
mike97 Posted March 28, 2009 Author Share Posted March 28, 2009 its all fixed the end links were gone .put new ones in and all better :burnout: Link to comment Share on other sites More sharing options...
