GomerPiles Posted March 19, 2009 Share Posted March 19, 2009 (edited) I have an 85 subaru gl wagon 4wd dual range and it wont idle. i can have it running and drive it but every timne i stop or put in the clutch it just dies, so i have to restart my car unless i time it right with the brake and gas and keep her running. but i think its the carb so im planning on buying a weber. but does anyone have any ideas before i spend money on a new carb? need the help bad. ohh another thing, i can get it to idle if im just starting it and i lightly press the gas it will idle. its like its constantly flooding ro chgoking itself out Edited March 19, 2009 by GomerPiles needed more detail Quote Link to comment Share on other sites More sharing options...
opus Posted March 19, 2009 Share Posted March 19, 2009 Can you raise the idle using the adjusting screw? Is the wire to the anti-stall still connected and working? Quote Link to comment Share on other sites More sharing options...
ferox Posted March 19, 2009 Share Posted March 19, 2009 There's a good chance it's your carb., but you could change your PCV valve and clean the PCV hoses. It can only help, and it's cheap and easy. Get a PCV valve from the dealer, they are much better than aftermarket.~$9 Quote Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted March 19, 2009 Share Posted March 19, 2009 Check your vacuum lines. Also make sure your air cleaner bolts have an O-ring under them, it is vital that you have the airbox sealed, other than the intake, of course. The bolts on the side of the air cleaner also must be in so as not to allow any extra air in as well. Twitch Quote Link to comment Share on other sites More sharing options...
ihscout54 Posted March 19, 2009 Share Posted March 19, 2009 (edited) Only when warm? Do you keep the rpms pretty high to keep it running? If you think it is flooding, check to see if it is, but it sounds more like good old fashoned vacuume leak/leaks. See if the carb is loose at the base or in the middle of the carb. You can check the PCV by plugging it temporarily. I do not know the EA82's but the air box alone should'nt be enough to prevent the car from idling. Though it is part of the vacuume system, and yes sealed is best. You could screw with idle speed and mixture but you probably should be checking for vacuume leaks first if you can keep it running. Edited March 19, 2009 by ihscout54 Quote Link to comment Share on other sites More sharing options...
