viceversa Posted January 18, 2004 Share Posted January 18, 2004 92 loyale. Auto 3 speed tranny has either been fixed or replaced 2 years ago. I checked tranny fluid a month ago and whoa! It was 1.25 qt. low. I added it all. Checked it today and it was about 1/2 qt low. I checked it in park. Where is the fluid going? Link to comment Share on other sites More sharing options...
GLCraig Posted January 18, 2004 Share Posted January 18, 2004 Pull the vacuum line off of the vacuum modulator and see if there is any fluid in the line or comming out of the modulator. It's pretty common for the modulator to go bad and allow fluid to be sucked into the engine through the vacuum line. Link to comment Share on other sites More sharing options...
viceversa Posted January 19, 2004 Author Share Posted January 19, 2004 Which side of the tranny is the vacuum regulator located? Neither Chilton's nor Haynes mention anything about it (like that comes as a surprise). Link to comment Share on other sites More sharing options...
MilesFox Posted January 19, 2004 Share Posted January 19, 2004 check the front diff gear oil for signs of ATF Link to comment Share on other sites More sharing options...
