Losing transmission fluid
92 loyale. Auto 3 speed tranny has either been fixed or replaced 2 years ago.
I checked tranny fluid a month ago and whoa! It was 1.25 qt. low. I added it all. Checked it today and it was about 1/2 qt low. I checked it in park. Where is the fluid going?
Pull the vacuum line off of the vacuum modulator and see if there is any fluid in the line or comming out of the modulator. It's pretty common for the modulator to go bad and allow fluid to be sucked into the engine through the vacuum line.
