what huh Posted March 21, 2009 Share Posted March 21, 2009 My question is will a carbed subaru motor run if the gas is gravity feed? So that you wouldnt have to worry about a fuel pump. For example: how motorcycles are set-up Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted March 21, 2009 Share Posted March 21, 2009 That will Work only if the Gas Tank & Lines are Vacuum / Presurized, but it Certainly will make your Subie Very Unsafe... ...or I Can`t Figure out how to Hold a Can of Fuel Over the Engine while Driving... I`ve Tried Feed the Carb with a Can but only for Testing Fuel System Purposes, only for a While... Link to comment Share on other sites More sharing options...
mountaingoatgruff Posted March 21, 2009 Share Posted March 21, 2009 it might, but i'd be hard to drive with a fuel tank bolted to your hood... but seriously, what are you trying to use this for? surely it can't be that difficult to rig a pump, and in just about any application i can think of its much safer. Link to comment Share on other sites More sharing options...
backinbrat Posted March 21, 2009 Share Posted March 21, 2009 pressure regulator, thats how i got round it in theory im running half 1 PSI, 1 at tops good point why would you not just rig up a pump? lol Link to comment Share on other sites More sharing options...
Quidam Posted March 22, 2009 Share Posted March 22, 2009 it might, but i'd be hard to drive with a fuel tank bolted to your hood... . I was thinking roof rack. About 1 psi per foot of elevation... Link to comment Share on other sites More sharing options...
what huh Posted March 22, 2009 Author Share Posted March 22, 2009 this is for a project that im working on. But from doing research it looks like it would be easier to use a pump anyways. the reason why i was asking was because i wanted to see if i could knock off some fabrication of my list of things to do. But there are more pros than cons to running a pump so that is what im going to do side note: Does anybody have EJ22 with a FWD auto? I need a measurement from the front of the crank pulley to the back of the tranmission Link to comment Share on other sites More sharing options...
