We have a 95 2.2L , I think the 2.5L's that came out about 97 and the next years were the problem. Search this site with head gasket, 2.5L engine and you should learn which had problems. I'm sure most of them have been repaired since then, Good Luck!!!
Sometime in the 02 production run, Subaru changed the head gaskets. If you have an 02, Subaru will pay for the head gasket replacement, up to 100k, only up to Vin number before the change. My 02 has a Vin after the change. So in theory, all the 03's and later are OK.
